Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 12-09-2011, 03:56 PM   #1
dabailjumper
dabailjumper 51
Default all warning lights on
i have a 2006 xb, recently all the warning lights came on, yet before that when i drive to work , the car acts as if its running out of gas(even on a full tank), it will do this for a couple of times , then it would run as if nothing is wrong, yet recenty i was getting ready to turn the car off , and all the warning lights came on, the radio blinked off, and will not power back on, the heater and wipers work, yet the battery has drainded. to me this sounds like and electricle problem, anyone has a clue
dabailjumper is offline   Reply With Quote
Old 12-09-2011, 07:58 PM   #2
aryana159
aryana159's Avatar
aryana159 23/M
i had a simular problem in my tc gen 1 happened after i installed my sub and head unit.
well there was simular problem i would drive and it would go all crazy with lights on the dash and when i would turn the head lights on it would die out. it made no sense to me thought the wiring was the issue.
well what ended up being a fuse under my hood one of the big ones not the normal size one i would say check all of your fuses first.
so just check fuses.
AUTO TO 5 SPEED SWAP
BOOSTED
PHONE UNLOCKING AND REPAIRS IN THE DFW AREA CALL OR TXT ME @ 972-989-1706
LONE STAR MOBILE
LOCATED IN IRVING MALL HAVE BEEN THERE FOR OVER TEN YEARS!!!!
aryana159 is offline   Reply With Quote
Old 12-09-2011, 08:42 PM   #3
Reactor
Reactor 42/M
This may help you with checking the fuses: http://www.clubxb.com/forums/showthread.php?t=42822
Would be great if you could check the battery voltage and scan the ECU to see if it has any trouble codes stored.
Reactor is offline   Reply With Quote
Old 03-03-2012, 02:14 AM   #4
jesteratc
jesteratc's Avatar
jesteratc 27/M
Possible Alternator Problem. Had similar issues with my other cars
the dumpsters were full, Jersey was full
jesteratc is offline   Reply With Quote
Old 08-21-2013, 09:03 PM   #5
hickup
hickup 49
Hope this helps,06 xb recently all my warning lights came on and i went the whole gambit trying to find the problem even searching this forum and talking to several scion owners with the same problem. About a week later my son told me there was a funny sound coming from the rear, I drove it and there was a weird sound on the drivers rear, We had recently put on custom wheels that were a bit wider than stock so I felt around the backside to see if there was any rubbing and I felt a wire rubbing the tire, I removed the wheel and the brake sensing wire had completely rubbed through. I soldiered the wires back together and secured the cable with an additional clamp and within seconds of driving it the lights went off! I called the others I talked to and they all had the same problem and results. Good luck!
hickup is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
06, 2006, car, cars, dash, died, indicator, lights, on, scion, shut, signs, warning, warnings, xa, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
