Register Forgot Password?
Reply
Old 12-28-2011, 11:25 PM   #1
Kai99
Kai99's Avatar
Kai99 25/M
Default Question about Transmission fluid&power steering fluids.
Hi all
I just got done my 36k services at a shop, they did a full inspection, recommanded me to flush my transimission and powersteering fluids.
Is it necessary for 36k?
Thank you.
Kai99 is offline   Reply With Quote
Old 12-29-2011, 12:53 AM   #2
thendawg
thendawg's Avatar
thendawg 26/M
Send a message via AIM to thendawg Send a message via Yahoo to thendawg
On a 2009, the ATF is SUPPOSED to be a lifetime fluid. No need to service it unless you have an issue with the trans. As for power steering, I believe its recommended every 36k, but I never changed mine until I built the motor and everything (I was around 70K). When I dropped the motor back in i flushed it and put all new fluid in it, however the old fluid looked fine. Up to you on that.
thendawg is offline   Reply With Quote
Old 12-29-2011, 10:19 PM   #3
tomb302
tomb302 31
phro7s phro7s
Does this also apply to the 2006 Models as well?
tomb302 is offline   Reply With Quote
Old 12-29-2011, 10:26 PM   #4
Jon
Administrator
Administrator
Jon's Avatar
Jon 24/M
Icebergg Slimm
Send a message via AIM to Jon
Isn't the first a/t transmission flush recommended at 120k? I think that's what the maintenance book says.
Jon is offline   Reply With Quote
Old 12-29-2011, 11:35 PM   #5
thendawg
thendawg's Avatar
thendawg 26/M
Heres the TSB on the WS fluid. TC's from 07-up used WS. 05-06 used the older T-IV ATF which followed a standard service interval. According to the TSB it should be inspected at 100k but never actually serviced/flushed. Funny enough, the trans itself didnt actually change. When I boosted my auto I drained the WS fluid, flushed it, and put in Royal Purple Max ATF which qualifies as a T-IV. It helped alot with the shifting under full throttle. WS is designed to be longer life and more efficient, but seems to not do to well in harsh conditions.
http://www.etimago.com/yaris/TSB/TS-...0Fluid%20).pdf
Old 12-30-2011, 10:14 AM   #6
Kai99
Kai99's Avatar
Kai99 25/M
Thanks guys.
Guess I will hold onto it for another 30k then........
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2006, 70k, fluid, power, purple, royal, scion, steering, tc, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
