Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 01-01-2012, 12:42 AM   #1
andyc0313
andyc0313 20/M
Default Oil light flickers after engine build
Hey guys!
I recently had my turbo motor rebuilt by a well-known shop in my area and the oil light has started to flicker after warming up. It only does it at idle and is coupled with a slight leaning of the mixture. The motor also got a new oil pump and I'm waiting on a new PCV valve from Toyota. It was supposedly align bored, although I don't remember being billed for that part, so now I'm questioning bearing clearances. I haven't had a chance to put an oil pressure gauge on it yet as it's the holidays and parts stores are closed this weekend, so I'd appreciate any help!
Other than this issue, the car drives fine and feels strong, although the new, lower compression means I don't really know how "strong" feels yet, without boost.
If it's worth anything, I had the shop use ACL race bearings for everything and a new OEM crank.
Thanks in advance!
andyc0313 is offline   Reply With Quote
Old 01-01-2012, 09:36 AM   #2
DeAnzaJig
DeAnzaJig's Avatar
DeAnzaJig 22/M
that could be a number of things. first i would get a reading with a gauge to see if it is actually loosing oil pressure. that will give you a good start.
Craigslist Add: Never launched or driven hard
DeAnzaJig is offline   Reply With Quote
Old 01-01-2012, 07:36 PM   #3
aryana159
aryana159's Avatar
aryana159 22/M
when i had my motor built i had no such problem i am also using all acl race bearings also but original crank.
make sure that the car has oil in fresh motors are now to eat a bit of oil in the break in process.
AUTO TO 5 SPEED SWAP
BOOSTED
PHONE UNLOCKING AND REPAIRS IN THE DFW AREA CALL OR TXT ME @ 972-989-1706
LONE STAR MOBILE
LOCATED IN IRVING MALL HAVE BEEN THERE FOR OVER TEN YEARS!!!!
aryana159 is offline   Reply With Quote
Old 01-01-2012, 09:18 PM   #4
thendawg
thendawg's Avatar
thendawg 26/M
Send a message via AIM to thendawg Send a message via Yahoo to thendawg
If they didnt clearance the bearings properly an excessive clearance could lead to lower oil pressure which could cause the light to flicker if it drops below the threshold. Im assuming youve already checked the oil level to make sure its just not low on oil? Also what weight oil are you using? If the clearances are a tad big (but still within reason) you could run a heavier oil. I personally run 10w40, and Ive heard of people running a 15w50. Remember this is a race engine, not stock. Alot of engine builders keep things looser so they dont get to tight with excessive heat.
thendawg is offline   Reply With Quote
Old 01-03-2012, 01:39 AM   #5
borderguy881
borderguy881's Avatar
borderguy881 24/M
Send a message via AIM to borderguy881
Also keep in mind our engines idle oil pressure is not to drop below 4psi per the manual and boy is 4 psi low
borderguy881 is offline   Reply With Quote
Old 01-03-2012, 04:21 AM   #6
ESEMRFOZZ13
ESEMRFOZZ13's Avatar
ESEMRFOZZ13 33/M
Quote:
that 50 weight is a beast in winter. i used it in my vw days.
ESEMRFOZZ13 is offline   Reply With Quote
Old 01-03-2012, 05:27 PM   #7
andyc0313
andyc0313 20/M
Thanks for the replies guys! I checked it with a gauge and it's getting 0 psi at idle and jumps to around 10 at 3k rpms. This if from a reading at the sending unit so I am currently trying to pull that OCV valve filter on the back of the block and see if it's clogged, since I had previously spun a bearing and it might have pieces in there. I feel like the bottom end is getting oiled but that filter is preventing top end pressure. Also, I'm running 10w30 right now but it was just for this first oil change then I plan on moving to something a tad thicker.
I thought it could've been the bearings at first, but I'm a little in doubt that a slightly off clearance would cause 0 psi at idle, or am I wrong? My engine builder and I both agreed that everything sat fantastic so I'm at a loss.
Old 01-03-2012, 06:30 PM   #8
thendawg
thendawg's Avatar
thendawg 26/M
The OCV filter would not restrict oil to the sending unit. It only filters oil going to the VVTI actuator. You could have a blocked oil passage in the block or head, thats really my only guess if its actually running. if you were getting no oil pressure on the bottom end at idle, odds are youd have spun another bearing by now.
Old 01-03-2012, 06:37 PM   #9
andyc0313
andyc0313 20/M
That's what I'm thinking. I ran it for about two days with this issue until I actually checked the oil pressure. Should I pull the head?
Old 01-03-2012, 10:08 PM   #10
GUNNIST14
GUNNIST14's Avatar
GUNNIST14 26/M
-Pull the oil pan and check the bearings then check the head.
-Lack of oil to VVTI actuator can cause issuses which you definitely don't want.
-Oh!! Also did you do a Balance shaft delete/removal on your motor?
If so make sure the oil feed passage for the balance shafts are blocked off.
Good luck bro I'm in the same boat kinda. My built motor knocks at idle. I hope it's a bad oil pump.
THOU SHALL ONLY LIVE FOR BOOST
INFOWARS.COM Because there is a war on your mind.
Precision Turbo-Spend Less,Race More.
GUNNIST14 is offline   Reply With Quote
Old 01-03-2012, 11:45 PM   #11
thendawg
thendawg's Avatar
thendawg 26/M
____ didnt even think about that. Yeah make sure if you removed the balance shafts that the oil feed for them is plugged.
Old 01-04-2012, 01:00 AM   #12
andyc0313
andyc0313 20/M
Actually, now that I think about it, the oil feed for the balance shaft was not plugged. Would this cause a significant drop in pressure like I'm having?
Old 01-04-2012, 01:05 AM   #13
aryana159
aryana159's Avatar
aryana159 22/M
yes that is a pressured oil line if its open building no pressure easy fix pop oil pan off and seal it up not to hard. i threaded in a bolt with abunch of jb weld worked for me
BOOSTED
LONE STAR MOBILE
Old 01-04-2012, 01:20 AM   #14
sebbyxtc
sebbyxtc's Avatar
sebbyxtc 21/M
sebbyxtc sebbyoner
Plug up the oil passage for the balance shafts and report back!
sebbyxtc is offline   Reply With Quote
Old 01-04-2012, 01:20 AM   #15
andyc0313
andyc0313 20/M
wowww that makes a lot of sense. I'll plug the hole tomorrow after work. I assume you have to tap it first, so does anyone have a size of tap and bolt for that?
Old 01-04-2012, 01:24 AM   #16
aryana159
aryana159's Avatar
aryana159 22/M
i just dad a bolt laying around i didnt tap it at all
BOOSTED
LONE STAR MOBILE
Old 01-04-2012, 01:26 AM   #17
andyc0313
andyc0313 20/M
should I just insert a bolt and JB weld? or tap it and threadlocker it?
Old 01-04-2012, 01:27 AM   #18
aryana159
aryana159's Avatar
aryana159 22/M
some one else chime in i used jb weld
BOOSTED
LONE STAR MOBILE
Old 01-04-2012, 01:53 AM   #19
sebbyxtc
sebbyxtc's Avatar
sebbyxtc 21/M
sebbyxtc sebbyoner
Ask DeanzaJig he plugged up my oil passage on my semi built block, not sure what he used. Or ask crush.
Old 01-04-2012, 02:03 AM   #20
borderguy881
borderguy881 24/M
Quote:
thread locker wont seal it considering its pressurized, jb weld will do the trick just be just to clean off ALL oil arounf the area as jb hates bonding to oil surfaces
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
build, engine, flicker, flickering, flickers, idle, light, oil, running, scion, scionflicker, scionlife, tc, toyota, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
