Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Suspension & Handling
Register Forgot Password?
Reply
Old 02-20-2012, 12:48 AM   #1
lowandslowtc
lowandslowtc 23
Default Steering / Suspension issue!!
Hi I am new to this forum, I bought a tc 2 years ago and have not had any problems till lately. The car is a 05 has 80,000 on it. The problem I am having is that when i am going around a corner ( usually over 30mph like on a highway ramp) the steering feels like it shifts. Also there is a pop I can sometimes hear and feel it in the steering wheel.
When I come out of the turn my alignment of the steering wheel to the wheels is off. I will go into the corner with the steering wheel slightly to the right( my alignment is off but I refuse to get it aligned till I figure this out) and when i come out of the corner it will be straight. The alignment is straight as an arrow the whole time its like the steering wheel shifts.
I am not sure how else to describe it. I can feel the wheel get loose for a second during the corner and the steering suddenly isn't enough to continue the turn, I have to turn the wheel even more to make it.
The related mods i have are D2 RS coil overs and new sway bar end links also enkei super 7's. I was thinking it might be a tie rod or a ball joint. I hope it is not the rack. I do not want to take it some where because they will prob jerk me around.Any ideas on what it may be would be much appreciated.
BTW I know you guys are big on the searching but I looked at everything i could pull up and I couldn't find anything quite the same.
lowandslowtc is offline   Reply With Quote
Old 02-20-2012, 04:01 AM   #2
bbtpd
bbtpd's Avatar
bbtpd 21/M
I don't know if this is related but I once went over a bump in my tC and I felt something pop in my steering column and my power steering went dead for a second. Afterwords my steering wheel was slightly turned to the left even though my car was tracking straight. Only happened once and there were no other problems to speak of. I took it in to be aligned and I told them my steering wheel was off and thirty minutes later my wheels are aligned and my steering wheel was straight.
I only ever had this happen once and it seems that this is a recurring thing for you so maybe its related, maybe its not.
bbtpd is offline   Reply With Quote
Old 02-20-2012, 04:15 AM   #3
lowandslowtc
lowandslowtc 23
Thanks for the reply. This happens daily some days worse then others I don't think it is the power steering I do not have trouble turning the wheel or anything and the fluid is full.
Old 02-20-2012, 05:31 PM   #4
mxyooji
mxyooji 28
I have a similar "pop / click" feeling in my 05 TC as well with 118K right now, I was once told it could be the intermediate shaft for the steering column. Get that checked out
mxyooji is offline   Reply With Quote
Old 02-20-2012, 09:38 PM   #5
lowandslowtc
lowandslowtc 23
Do you think the intermediate shaft could cause the shift in the steering? I am not worried as much about the noise. I am worried about the shift in the steering. I will have to get the intermediate shaft checked out.
Old 02-21-2012, 06:56 PM   #6
lowandslowtc
lowandslowtc 23
Also I recently had my drivers side drive shaft replaced and I didnt notice this issue until after that. Could there be a problem with that? Improper installation?
Old 02-21-2012, 07:52 PM   #7
mxyooji
mxyooji 28
if your steering wheel isn't in line / straight when your vehicle is going on a straight way, it's off centered and that usually results from installing coilovers / springs. you can just get a shop to re-center it.
Old 02-23-2012, 04:53 AM   #8
mrjtang
mrjtang 27
does it make a clunking noise when you're turning? if it does, it could be a loose bolt. retorque your bolts.
mrjtang is offline   Reply With Quote
Old 02-24-2012, 02:14 PM   #9
lowandslowtc
lowandslowtc 23
Thanks for the reply. It does make a clunking noise. I will have to get under there this weekend and check the torque on the bolts to see if that is the issue. Hopefully that's the issue.
Old 02-24-2012, 05:01 PM   #10
mrjtang
mrjtang 27
keep us posted
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
09, 2009, car, click, d2, intermediate, issues, knocking, put, scion, shaft, steering, suspension, tc, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
