Register Forgot Password?
Reply
Old 03-29-2005, 03:07 AM   #1
yellot00tr
yellot00tr 32/M
Send a message via AIM to yellot00tr
Default gas testing question
i looked thru the search stuff quickly and didn't think i saw this anywhere on sl so i'm gonna ask it-i heard that when scion did the testing for the tc and came up with numbers such as hp, torque, etc that they did it with premium gasoline. supposedly it says that in the manual. did anyone happen to see it-i'm pretty sure that i never saw it in there although its supposed to be there somewhere.
yellot00tr is offline   Reply With Quote
Old 03-29-2005, 03:11 AM   #2
TurboMe
TurboMe 113/M
hmm interesting never heard of it.
TurboMe is offline   Reply With Quote
Old 03-29-2005, 07:51 AM   #3
Otocan
Otocan's Avatar
Otocan 113/M
Send a message via AIM to Otocan Send a message via MSN to Otocan
the only time higher anti-knock gasoline ratings will affect your numbers out of your engine is if your ECU is retarding the ignition timing to prevent pre-combustion (and no, I didn't google that I'm just good)
unless the compression ratio is high enough to pre-combust 87 octane gasoline (9.6:1 is hardly high compression) then you will see no benefit from running higher gasoline, and the owners manual tells you to run 87 octane for best results. If you should need higher octane then your manual would tell you to run it like every other car's manual that requires higher octane fuel.
A sutdy at Cabmirgde Unvireisty shwos taht the hmuan brian deosn't raed ecah letetr of a wrod, but the wrod as a wohle. Olny the frist and lsat lteters hvae to be the smae. The rset can be a hgue mses and be raed wihtuot mcuh of a porlbem. Prtety werid,huh?
Too Many Options To List -See Profile
http://www.newgrounds.com/portal/view/206373
Otocan is offline   Reply With Quote
Old 03-29-2005, 04:47 PM   #4
reagulator
reagulator 26/M
in order to get more power from a higher octane rating is to advance the ignition timing, which btw isnt as easy as it used to be
H&R sport springs + Hotchkis Sways + Injen Intake + Alphawerks header + White LED Guages + ScanGauge + B&M short shifter + Koito Whitebeam Headlights + Luminic Yellow Fogs + kenwood 7017 + diamond audio D-series Comps + kappa perfect 10 + alpine F345 amp.
reagulator is offline   Reply With Quote
Old 03-29-2005, 05:18 PM   #5
JasonH
JasonH's Avatar
JasonH 38/M
Quote:
Right, because if you are able to advance it mechanically, the ECU will just set it back to stock electronically.
Unless your car requires the use of premium fuel, there is no reason to use more than the recommended octane rating. Unless you modify the ECU or add forced induction premium gas will only make your wallet lighter.
'05 Scion tC - Black Cherry Pearl - 5-speed
My Cardomain Page
Learn To Search: CLICK HERE
JasonH is offline   Reply With Quote
Old 03-29-2005, 05:30 PM   #6
icdedppl
icdedppl 34/M
yeah, higher octane won't do you any real good with a tc. and yes, it does say that in the manual in several places. i have the manual in electronic format and found it on 3 pages. here it is on one of them, copied/pasted:
page 132-
OCTANE RATING
Select Octane Rating 87 (Research Octane
Number 91) or higher.
icdedppl is offline   Reply With Quote
Old 03-29-2005, 05:34 PM   #7
reagulator
reagulator 26/M
in rare cases useing premium would cause damage to your engine because of the slow burning nature of premium gas the fuel will still be in the combustion stage as it exits your engine. When you use regular gas the engine makes a spark at TDC or somewhere around TDC, but with premium you have to create a spark earlier to take advantage of the slower burning gas thats why you advance the timing. You actually have to make a spark when the piston is still moving up in the compression stage.
I hope that made sense. i have to go to work now
Old 03-29-2005, 05:38 PM   #8
jmiller20874
jmiller20874 34/M
Quote:
page 132-
OCTANE RATING
"Research Octane" is a different number from what you see on the pump, hence 91 "Research Octane" is not premium gas.
Taken from Shell's website:
Quote:
Technically there are three different "octane numbers" associated with every gasoline. The Research Octane Number, or RON, is measured under fairly easy test conditions. The Motor Octane Number, or MON, is a tougher test measured at higher engine speed and temperature.
The value that relates most closely to actual driving conditions is the average of these two values: Road Octane Number = (RON + MON)/2
Look at any gas pump in the U.S. and you'll see this formula stuck there:
Octane = (R + M)/2
2007 Toyota Sienna Limited AWD w/ tons of goodies.
Bye, bye tC. You will be missed.
jmiller20874 is offline   Reply With Quote
Old 03-29-2005, 06:58 PM   #9
Daemon1313
Daemon1313
yeah, what jmiller20874 said.
Daemon1313 is offline   Reply With Quote
Old 04-04-2005, 07:07 PM   #10
gavmitchau
gavmitchau 33/M
Send a message via ICQ to gavmitchau Send a message via AIM to gavmitchau
nice. thx for the info guys
gavmitchau is offline   Reply With Quote
Old 04-04-2005, 07:50 PM   #11
mancide
mancide
Send a message via ICQ to mancide Send a message via AIM to mancide Send a message via MSN to mancide Send a message via Yahoo to mancide
page 132-
OCTANE RATING
I think this is the number people try and quote for justification of using premium in the tC. Basically it's them not understanding what the two different numbers mean. Like pretty much everyone says, 87 is all you need to put in your tank. You won't mess it up with premium, but why waste the extra money if there is no direct benefit.
mancide is offline   Reply With Quote
Old 04-04-2005, 08:13 PM   #12
George
George's Avatar
George 113/M
Research Octane number is the number used in Europe. My '71 VW bus also specifies 91 RON.
In the US, we use the average of the Research and Motor method octane number, This is referreed to as "(R+M)/2" The two methods are simply different test procedures using the same equipment.
George is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
