Rear view camera
Old 03-25-2012, 05:58 PM
v-train's Avatar
Default Rear view camera
I'm gna install a rear view camera. I pretty much have an idea of what to do as far as getting the wire through Licence plate To the trunk on my tc. But then where do I run it on the roof? How do i run it from the roof to my indash? And also is there a reverse light power wire in the dashboard where I could tap power from? Thanks all help is appreciated
v-train is offline
Old 03-25-2012, 06:04 PM
TheMuffinMan00's Avatar
what year is your tc? I will look up the wiring for you. As far as running the wire you just have to figure that out as you go. If you have already figured out how to get from the license plate area through the hatch and from the hatch to the body of the car you should have no issue running it the rest of the way
TheMuffinMan00 is offline
Old 03-25-2012, 06:09 PM
v-train's Avatar
My tc is 2010. Yeah I don't know how to get from the roof to the dashboard. I was trying to find something on the tech section but nothing.Maybe il figure it out as I go along hopefully
v-train is offline
Old 03-25-2012, 09:09 PM
The reverse wire is
Pink + in the fuse box white 30 pin plug A pin number 30
To run to the front I would just tuck the wire in between the headliner and the plastic all the way till you get to the a pillar. Then go in between the outer metal removing the weather strip and run it that way till you get under the dash then from there it's easy. Make sure you run the wire BEHIND the airbag not over it.
Old 03-26-2012, 04:25 AM
v-train's Avatar
Damn the air bag part sounds dangerous. Are there airbag sensors there that triggers the airbags? If so what do they look like. Thanks for your help btw
v-train is offline
Old 03-26-2012, 04:38 AM
dsimp13's Avatar
No air bag sensors. Those should be in the bumper.
dsimp13 is offline
Old 03-26-2012, 03:31 PM
Yea you won't get near any sensors in what you are doing just don't cut any wiring on your way to the dash till you find that pink wire.
Old 03-26-2012, 04:56 PM
t_C
t_C's Avatar
If you're really concerned about going thru the headliner or the pillar with the airbags, you could certianly take the low road behind the trunk/rear side panels, under the door sill and to the fusebox. It will certainly require more wire and more removal.
t_C is offline
Old 04-02-2012, 03:04 AM
dsimp13's Avatar
Did you ever get the camera installed?
dsimp13 is offline
yoson13
Scion xA Aero & Exterior
13
08-29-2015 11:12 PM
sciontcguy15912
03-27-2015 09:06 PM
XB06
02-16-2015 06:03 PM
evolving_machine
01-13-2015 08:04 PM
arinvolvo
37
12-19-2003 06:00 AM
Quick Reply: Rear view camera
