tC: 2006 tC Partout...wheels, turbo, audio, suspension, exhaust
Old Apr 7, 2012 | 09:11 PM
t_C's Avatar
t_C
Cool 2006 tC Partout...wheels, turbo, audio, suspension, exhaust
All parts were on a 2006 tC, mileage varies and is listed as applicable next to the item. Most mileage accumulated was highway as I always worked at least 25miles away during ownership.
Location of said parts is SE Michigan, zip code 48073.
Prices are listed without paypal or shipping costs and everything is considered OBO; buyers will pay exact shipping costs + paypal fees.
Typically, the items that are listed together will not be separated.
I will update items when they are sold...if there is a price listed the item is still available.
On to the goods…
SUSPENSION/WHEELS
HKS Hipermax RS Coilovers__________(SOLD)
~15K miles.
Incredibly comfortable and rare set of 30-way dampening and rebound adjustable coilovers. With all the development HKS put into this set it is sad to see them discontinued. Front has aluminum pillowball upper mounts however this set reuses your factory rear upper mount and requires a wall-mounted spring compressor to perform the swap.
Spring rates are 5kgf/mm FRONT and 4kgf/mm REAR.
RAYS ENGINEERING G-GAMES 77S__________$750
g-games 77 Sidewinders :18 x 8.5 / +48 offset / 5 x 100 bolt pattern. They weigh in at 19lbs (w/o tires).
~15K miles.
These currently have a set of throw-away tires on them, so its priced for wheels only. There is some curb rash on the lip only of 2 of the wheels as shown in the pics (you can thank the ex-gf for that). Easily repairable.
Hotchkis Front Strut Bar__________$75
~50K miles
Ingalls “Stiffy” Engine Dampener__________$75
~35K miles
INTAKE/EXHAUST
Draxas Cat-Back Exhaust__________$375
~35K miles. Best sounding exhaust for the tC in my opinion; I’ve gotten many compliments from scion and non-scion enthusiasts alike.
YouTube sound clips courtesy of socnate23: http://www.youtube.com/watch?v=8I0QCc-xoFo
Draxas S-Pipe__________$90
~35K miles.
Modified with 2nd port for a WideBand O2 gauge; I’ll include a threaded plug if you’re not using a gauge.
Stock MAF__________$40
~20K miles.
FORCED INDUCTION
Again, items listed won’t be separated, but I am certainly willing to work with package deals for someone looking for a complete setup.
Turbonetics Turbo Kit__________$1750
~25K miles.
Upgrades include water cooled center section and redesigned downpipe with slip-fit @ waste gate. Extras include vacuum manifold, pre-tapped oil pan with barb fitting for rubber line, and the Turbonetics stainless water line kit for turbo.
Note that charge piping was in ‘typical’ condition for the Turbonetics coating (peeling, fading, flaking), but I am willing to have it stripped and re-powder coated for an additional cost.
Saikou Michi Dual Oil Catch Can__________$80
http://www.saikoumichi.com/
One of the best dual chamber designs out there; I easily mounted it low on the driver’s side for convenient access to drain during oil changes. You’ll need to supply your own hoses.
AutoMeter Cobalt 6107 2-1/16” Boost/Vac Gauge__________$50
Does not include hard line tubing, but I am providing a harness with fuse tap for mounting in the cubby area; this may also be enough length to a pillar mount.
AEM UEGO Wideband__________(SOLD)
APEXI Turbo Timer__________$65
Fully harnessed ready to install, simply provide a few of your own T-Taps.
http://apexi-usa.com/shop/index.php/auto-timer-electronics.html
DRIVETRAIN
NST Shifter cable bushings__________$15
Creative Compacts Shift Knob__________(SOLD)
Never used. This weighted **** came with their short shifter (which I decided to leave for the new owner, as it should have come that way from the factory.)
INTERIOR/EXTERIOR
S2000 Antenna__________(SOLD)
4pc FIG Grill__________$75
Good condition, small rock chips shown in close-up photos.
RS3.0 TYC Tail Lights__________(SOLD)
New condition; Original owner removed these after ~ 1K miles.
YAKIMA Roof Rack System__________$275
Includes Q towers, 58” crossbars, Q99/Q83 clips and matching lock cylinders
YAKIMA Fork Mount Bike Carrier__________$75
Keyed to match roof rack system
Carbon Fiber Cubby Dual Gauge Holder__________(SOLD)
AEM Oil Cap__________(SOLD)
Billet. purple-ish color.
Passenger Side View Mirror_________$25
Housing is painted classic silver metallic and comes with all internals but no glass. Housing is cracked on the inside corner, but could be repaired to nearly invisible or used for parts; paint is in excellent condition.
AUDIO
In addition to the items listed here, I have several power distribution setups from 0-gage to 4-gage, high quality RCA’s and other install accessories from many personal installs. If you need something to complete your purchase and simplify installation just ask!
ALPINE CDA-9835 with KCA-420i iPOD Adapter__________$325
http://vault.alpine-usa.com/products/documents/OM%20CDA-9833.pdf
Top quality, very capable and adjustable car audio receiver; Alpine went thru every effort on this one. 24bit burr-brown DAC’s, external DC/DC converter and internal amp shutoff further remove electrical noise. Massive default and custom EQ settings, time correction(Awesome!) and crossover controls let you fine tune your sounds, media eXpander brings in highs and lows for low-volume listening. Multicolor lighting and OEL display let you match your current interior theme.
Includes tC specific dash mount w/cubby and pre-wired harness (wired for external amplification - i.e. no speaker wires in harness)
PAC SWI-X__________(SOLD)
http://pac-audio.com/productDetails.aspx?ProductId=212&CategoryID=29
JL AUDIO 12W7__________$475
http://issuu.com/talkaudio/docs/12w7_manual
HEAVY! Both in weight and in sound! I have the original box to ship this in safely, but it won't be cheap; recommend pickup.
Custom Sealed Fiberglass Enclosure for W7__________$125
I made this back in 2007, designed around the concept of a false floor to house the amps AND the spare tire (I never needed the spare in those 5 years…go figure). It’s cutout for (11.9” cutout and 12.7” bolt circle) and right at the recommended volume (of 1.3cuft) for a 12w7. Installation requires removal of the passenger side trunk panel, carpet and foam floor supports to achieve this volume of sound in a compact space; retains the full travel of the rear seat recline function on the passenger side. I would like to see this go to a good home.
JL Slash 1000/1__________$425
http://mediacdn.shopatron.com/media/mfg/9013/media_document/live_1/1000_1_MAN.pdf?1317780748
Combined with the w7 & a sealed enclosure I couldn’t be in the car when the gain was tuned to JL specs and the volume was up, it would literally take your breath away. MSRP on this was > $1K new
JL Slash 300/2__________$275
http://mediacdn.shopatron.com/media/mfg/9013/media_document/live_1/300_2_MAN.pdf?1317780848
New-in-box. This was going to be part of the bi-amp setup for the 6.5’s in my previous car before I got rid of it, amp has been sitting in my closet ever since.
Boston Acoustics PRO 5.5 2-way__________$150
http://www.bostonacoustics.com/assets/bostonmobile/manuals/ProSeriesCompMan.pdf
MSRP $440. Excellent condition, bright sound; these will still bang hard for a long time. Have accessories including remote and axial tweeter mounts, grill covers, etc.
Boston Acoustics PRO 6.5 3-way__________$225
MSRP $750. Each of the 4” speakers have small tears in the surround which could be repaired or replaced with your choice of 4" (this wasn't the strenght of this system, its really the woofer/tweeter/crossover combination)
Rockford Fosgate 700x__________$250
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/575/575500X.PDF
87.5w x 4ch and it includes both endcaps (not pictured). This thing has served me very well over the years.
OEM Scion iPOD Cable__________$45
Old Apr 7, 2012 | 09:53 PM
jimho228's Avatar
Dibs PAC SWI-X, shipped to 36695, and paypal info?
Old Apr 7, 2012 | 11:14 PM
t_C's Avatar
t_C
Thumbs up PAC SWI-X
PM Sent!
Old Apr 7, 2012 | 11:35 PM
my06tc's Avatar
$55 on turbo timer !!!!!!!!!
Old Apr 8, 2012 | 04:29 AM
Txninja's Avatar
rail on roof rack 2 or one?
Old Apr 8, 2012 | 04:34 AM
jmyr's Avatar
pm'd!!!
wish i had more disposable money or i would take soo much more
Old Apr 8, 2012 | 06:49 AM
j3st3r's Avatar
Music City Scions
Dibs on the AEM Wideband....to 37167
Old Apr 8, 2012 | 12:53 PM
Cisco_TeamShogun's Avatar
Interested in the following: Draxas S-Pipe__________$90
is the design/fitment the same as an indivia/or other after market s pipes? Hows the fitment? I ask because I basically have a Tsudo midpipe " " its a modified pipe but fits just like the tsudo and unsure on how this will mate up. PLus I have a DC header, want to make sure I wont run to to much problems, I have heard that not all S pipes fit the same, some have slight bends on them that prevent them from mating up properly.
Thanks!
If I buy this, I will be interested on the wideband...so 2nd or 3rd dibs on that.
Old Apr 8, 2012 | 01:00 PM
t_C's Avatar
t_C
Thumbs up Turbo Timer
PM on its way....
Old Apr 8, 2012 | 01:05 PM
t_C's Avatar
t_C
Not sure i completely understand your question...
I only have one bike mount available; there are several other styles including this one available from Yakima.
The roof rack system alway requires (2) crossbars in order to mount just about anything
BTW, if positioned properly this thing clears the sunroof completely.
Old Apr 8, 2012 | 01:48 PM
t_C's Avatar
t_C
Originally Posted by jmyr
pm'd!!!
PM replied.
Old Apr 8, 2012 | 01:49 PM
t_C's Avatar
t_C
Thanks, your interest is noted however jmyr got in an offer thru PM first; i'll give him an opportunity to respond.
Current order on WBO2 is....
1. jmyr
2. j3st3r
3. Cisco_TeamShogun
Offers higher than asking will be given first priority.
Old Apr 8, 2012 | 02:00 PM
t_C's Avatar
t_C
Default Franken-exhaust
Thanks!
This pipe is similar or better than most on the market in terms of fitment to factory locations. I had no issue bolting up to factory exhaust manifold or the turbo downpipe when I switched over.
I cannot guarantee the fitment between a tsudo/modified tsudo midpipe and a DC header. If you're sure the two other sections are in factory locations then I don't see a problem.
You are currently 3rd in line for the wideband unless you are willing to offer over asking price. As stated the pipe would come with a plug so you can add a WBO2 later, but since I placed the bung to point up, out of harms way, it would be easier to install both together.
Old Apr 8, 2012 | 02:03 PM
t_C's Avatar
t_C
Originally Posted by SubrinaIsMyCar
wow great prices
Thanks...a lot of time and effort went into the presentation and market value research to make this fair for all in the end. This community has always been good to me, so I gotta show some appreciation.
Old Apr 8, 2012 | 04:09 PM
j3st3r's Avatar
Music City Scions
1. jmyr
2. j3st3r
3. Cisco_TeamShogun
Not looking for an auction here... You posted a price for what you are selling....I have asking price money in hand...period. If someone gave you an acceptable offer, and has the money then you should sell it. If you want to take bids post the stuff on eBay
Old Apr 8, 2012 | 05:23 PM
t_C's Avatar
t_C
Smile
Understood...and you're right it's not an auction
However, please note that I did disclose in my original post:
"A higher offer will overrule dibs at asking price or best offer"
I am giving the original buyer stated time to respond...clarified further in PM.
Happy Easter!
Old Apr 9, 2012 | 01:30 AM
EDDIEA123's Avatar
Nice part out.....I'm watching
Old Apr 9, 2012 | 01:42 AM
jmyr's Avatar
wideband and cubby pod SOLDDD
Old Apr 9, 2012 | 07:26 PM
EDDIEA123's Avatar
Grills shipped to 90044? Also specs on the G-games?
Old Apr 9, 2012 | 09:37 PM
Rezzle00's Avatar
PM'ed
