Injector grommets
Old May 16, 2012 | 07:55 PM
gp1817's Avatar
Default Injector grommets
where can i buy the grommets from..toyota right.....just wanna make sure,cause lost 2 out of 4 grommets while doing my injectors,wasnt careful..
Old May 16, 2012 | 08:52 PM
PeArLwHiTe07tC's Avatar
R u lookin for the insulators that sit in the head or the pintle caps that go onto the tip o the injectors? If its the insulators, the part # is 23291-41010. U can get em from the dealer. If its the pintle caps, u can get em from injector rehabs site. Hope this helps.
Old May 16, 2012 | 09:50 PM
Syldrin's Avatar
well at least you were honest.
Old May 16, 2012 | 11:54 PM
gp1817's Avatar
Stock grommet on the left,the right grommet the dealership gave me,they look totally different,question is ,can i use that, i told them 06 scion tc...they ask for the vin # which i didnt have
Old May 17, 2012 | 12:17 AM
Domo's Avatar
check trdsparks oem section
Old May 17, 2012 | 01:23 AM
gp1817's Avatar
yes the grommets that sit on the head,i thought the one that came with the car,would be the same as the one at the dealership,not sure if they changed them or not
Old May 17, 2012 | 01:30 AM
gp1817's Avatar
whats the pintle caps,do i need them with the grommets the dealer gave me,if i cant find my other ones......
Old May 17, 2012 | 02:18 AM
Syldrin's Avatar
more then likely the design was changed mid production.
Old May 17, 2012 | 02:40 AM
headlessmunky's Avatar
The new ones are fine. I have them on my car I bought them last week and they have held up. I soaked mine in some high mileage motor oil to let them swell a bit. I don't think it made a difference.
Old May 17, 2012 | 03:05 AM
The part # i gave u are correct. The ones the dealer gave u look correct. Theyre the same for all the tc's.
The pintle caps i was refering to, sit on the nozzle of the injector and sits in the grommet that u have there. Theyre the little black tip on the nozzle of the injector. If theyre on there, i wouldnt worry about it.
Old May 17, 2012 | 01:12 PM
gp1817's Avatar
do i need the pintle cap for these new grommets,or can i get away with just using these new ones without them,
Old May 17, 2012 | 03:21 PM
gp1817's Avatar
disregard the last post....i found my other grommets i lost...gonna use them...now whats the easiet way to get these injectors back in,any tricks
Old May 17, 2012 | 04:20 PM
gp1817's Avatar
injectors are in,i moved alot of crap out of the way,more room to work with,angle it,and went right into place...you think i can return those other grommets back to the dealer,even though they were never used or even put on the injectors
SloTC1
Aug 16, 2018 02:45 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
woodstock
Mar 24, 2005 07:21 PM
