Question about the Injen Polished Engine Cover ( Install )
Old Apr 2, 2005 | 08:13 PM
House_Of_Steel's Avatar
Default Question about the Injen Polished Engine Cover ( Install )
I just purchased the Injen Polished Aluminum Engine Cover and inside the box was the cover, 4 small round rubber grommets and also 2 larger, thicker ones and two small nuts.
QUESTION, there are no instructions on how to place the rubber grommets, do the large two slide down first over the studs and then place the cover on and then the smaller two thin grommets and then the nut ??
Also, on our factory cover, there is some type of a fiberglass insulation glued to it, do we remove this and reglue to the Injen Cover ?
Last but not least ..............
I need 4 really nice looking nuts to replace those factory nuts with ? I seen someone had nuts that almost looked like spikes, where can I get those ..
Thanks
Old Apr 2, 2005 | 08:25 PM
xmetalx's Avatar
the bigger rubber grommets go on first. and to answer your question about the bullet nuts, im not sure,
Old Apr 2, 2005 | 08:32 PM
YELOSUB's Avatar
Wagonistas
For the spikes, give randode a try. www.randode.com
Old Apr 2, 2005 | 08:48 PM
Satmax's Avatar
I would imagine you would install the large grommets on the top two studs, then with the cover on, install the 4 smaller grommets on the top two and front studs.
As far as the insulation goes, I gently pulled mine off the stock cover, then I used Velcro with adhesive backing and put two Velcro strips on the cover and pressed the insulation onto it. The insulation sticks to Velcro quite well. You can pick up the Velcro at any hobby shop like Michael's, Hobby Lobby, or anywhere that has sewing materials.
Old Apr 3, 2005 | 12:48 PM
That helps - Thanks
LostCause
Scion tC 2G Aero & Exterior
33
Jul 9, 2015 09:00 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
eric_m
79
Mar 17, 2013 12:21 AM
Phillip_Injen
39
Nov 4, 2003 10:38 PM
