Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 07-23-2012, 02:41 AM   #1
hike4life
hike4life 29
Default Squealing!
I have a 2005 XA and if the ac is on when I start my car there is this awful squealing. I recently replaced the serpentine belt and am in the process of trying to figure out what tools I need to replace the power steering belt. I got both belts from the dealer so they are good.
Does anyone know what the squealing could be?
hike4life is offline   Reply With Quote
Old 07-23-2012, 05:06 AM   #2
pyroman131
pyroman131's Avatar
pyroman131 26/M
Typically a squealing sound when turning on the car is belt related. Check the new belt you put on and make sure that it is defect-free and also check to make sure it's properly secured and the bolt is torqued to the correct number of ft-lbs. Then check out your power steering belt. Check it for defects and also check the torque with a torque wrench. After this, start the car and see if the squealing goes away. If it has not, replace your power steering belt also.
Proud 2008 Scion xB owner.
Second grade teacher with a sweet xB.
Wanted: xB2 Tsudo Fireball Dual Exhaust!
http://www.scionlife.com/forums/show....php?p=4070929
(As of 11/19/12)
pyroman131 is offline   Reply With Quote
Old 07-23-2012, 07:23 AM   #3
Ford_Falcon
Ford_Falcon 43/M
More than likely the belt doesn't have enough tension. You may have to loosen the alternator and then find something to put some tension on the alternator while you're tightening the bolt that goes through the bracket at the top.
As for the PS belt, since you'll need to adjust the alternator belt anyway, might as well go and take it off, then remove and replace the PS belt first.
Ford_Falcon is offline   Reply With Quote
Old 07-24-2012, 05:03 AM   #4
hike4life
hike4life 29
After much research and a very detailed phone call to my dad we think that the serpentine just isnt tight enough. I do want to replace the PS but I just cant reach and it is in an aquard place. Does anyone know of a tool that can reach that lil bolt that I cant reach? Or what has worked for other people?
Old 09-13-2012, 04:34 PM   #5
tabanowa
tabanowa 48
Question Belts squealing
I have this same problem with my 2005 xA! It used to stop if I turned off the A/C, but now it is just squealing all the time. I was going to try replacing all the belts - I tried spraying with belt conditioner, but it's not getting any better; in fact it's worse. Sounds like I need to tighten the tension? Please help before I spend money replacing things that don't need to be replaced - thanks!!
tabanowa is offline   Reply With Quote
Old 09-13-2012, 07:15 PM   #6
hike4life
hike4life 29
Hey tabanowa,
So what I ended up doing was replacing the serpentine belt and the power steering belt. The sound is gone now and honestly it isnt that expensive. The serpentine you can do yourself if you want to learn, but the power steering belt is a little hard to get to so I had it done for me. I did go to the dealership and bought Scion parts but you can go to Auto Zone if you want to. The belts dont live forever (though I wish they did!) so its probably time to have them replaced.
Best of luck!
Old 09-13-2012, 09:20 PM   #7
tabanowa
tabanowa 48
Thanks. I just came across a "troubleshooting belt noises" video and it says that belt dressing does NOT work and should never have been invented. Wish I had done my research before buying that product! Did you end up having to adjust the tension, or did the noise stop with just replacing both the serpentine and PS belts?
Old 09-14-2012, 07:55 AM   #8
turbolarry
turbolarry 40/M
I just had to tighten my belt up the other day. For the bottom bolt on the alternator I used a 3/8 Craftsman socket and a 14mm. Anything bigger and even the torque wrench hit the frame rail. To get tension I used a pry bar against the corner of the head and used the torque wrench with a 12mm on top.
http://scionlife.org/Scion_Docs/xA_M...Mechanical.pdf
If it doesn't make power, it's not worth the hour.
turbolarry is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
05, 06, ac, belt, drive, fan, power, scion, squealing, squeel, steering, torque, troubleshooting, xb, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
