Go Back   Scionlife.com » Scion FR-S » Scion FR-S Owner's Lounge
Register Forgot Password?
2013-____ [__?__]
Reply
Old 07-31-2012, 01:00 AM   #1
rhythmnsmoke
Music City Scions
rhythmnsmoke 4/M
Default InsideLine *FR-S vs Turbo Veloster*
http://www.insideline.com/scion/fr-s...ison-test.html
Attachment 11547
2013 Hyundai Veloster Turbo vs. 2013 Scion FR-S Comparison Test
Which $25K Sports Car Is the Real Deal?
Purists stand firm on the notion that few sports-car truths are more self-evident than the superiority of rear-wheel drive, full stop. This is a dogma that was fully embraced by the creators of the 2013 Scion FR-S to the extent that the car's very model name acronymically trumpets this fact.
And then the front-wheel-drive 2013 Hyundai Veloster Turbo goes and out-slaloms it. Yep, 68.0 mph to the Scion's 66.8 mph.
But let's take a step back. A more obvious competitor for the Scion FR-S is Hyundai's rear-drive Genesis Coupe. But what's this? The Veloster Turbo we tested costs $25,320 and generates 201 horsepower, stats that read as though lifted from the FR-S window sticker (our FR-S tester stickered at $24,930 and produces 200 hp). Get past the obvious dissimilarities in door count and drive wheels and we have a surprisingly level playing field. So let's see how they stack up in the real world.
Pace Makes the Difference
The Veloster Turbo is relatively lightweight at 2,910 pounds and the suspension is dialed up to a stiffness that's busy but not quite uncomfortable. Unraveling a winding road at what we call momentum pace — a quickish clip that's not so rapid that you have to brake for corners — the Veloster Turbo's responses suggest that promising things await those willing to draw more deeply from its well.
Unfortunately, the Veloster's well is shallow, and its chassis wilts when confronted with a more determined charge through the same canyon. Turn into a bend like you mean it and there's an elastic imprecision between your hands and the road as though there's too much sidewall flex in the Veloster's 215/40 Kumho Solus KH25 tires, or its suspension bushings are too soft. And the steering, though quick immediately off-center, slackens off as you wind on lock and is overboosted. Attempt to power out of a corner on the throttle and the Veloster Turbo does a one-tire fire, as there's no limited-slip differential. And it needs one.
The harder you drive it, the more the Veloster Turbo frustrates. Its modest ultimate grip of 0.83g is not the issue. It's the way it composes itself on imperfect roads. Even around town the rear suspension's sensitivity to bumps is obvious and when it encounters a pavement seam midcorner, the ___ end will step out several inches. The chassis also wallows as though underdamped when told to brake hard on lumpy bitumen. No wonder the logbook entries ranged from "it feels unfinished" to "This chassis is a mess."
Purpose-Built
Slide into the little FR-S coupe after wheeling the Veloster and you immediately notice that the Scion's seat is lower slung and more supportive, its structure is noticeably stiffer and the control interfaces move with more mechanical heft. It turns in with far more precision. The FR-S's brakes are firm and the pedal placement makes heel-and-toeing a cinch. While the Veloster's shifter is quick, it feels toylike in comparison to the Scion's more substantial-feeling gearchange. The FR-S's lever is a bit notchy and sometimes balks at downshifts into the 4th gear gate, but on balance it is a pleasure to row.
The Scion's steering is leagues sharper than the Veloster's, and better weighted besides. It tracks more honestly and isn't flustered at all by pockmarked pavement. On the smooth surface of our skid pad it produced a 0.90g orbit, considerably grippier than the Veloster. Braking the FR-S from 60 consumed 118 feet, edging the Veloster yet indicative of rubber that is on the meek end of its summer tire classification.
Yet it is tactility that defines the FR-S. This is a car that is completely at ease when the limits of its 215/45 Michelin Primacy HP tires are being explored, remaining sharp and communicative. It telegraphs clearly how to get the most out of it — ham-handed overdriving will drag the nose wide, yet prudent trail braking and throttle manipulations allow the balance of grip at both ends of the car to be managed. Extracting this balance in the FR-S is just loads of fun. And unlike the Veloster, this is a chassis that can clearly exploit more tire.
The Goods Under the Hood
That's not to say that all is bad in Velosterland. Its 1.6-liter turbocharged engine churns up a flexible torque curve and transitions into boost so seamlessly that you might not guess it's turbocharged. You step on it, and the creamy-smooth mill delivers satisfying hustle all the way through the midrange, tapering off as the 6,750-rpm rev limiter looms. At cruise, the engine note drops to a whisper. Despite channeling 195 pound-feet of torque to the front wheels, torque steer is essentially nonexistent.
In our testing it hit 60 mph in 7.7 seconds (7.4 seconds with 1 foot of rollout as on a drag strip) and the quarter-mile in 15.6 seconds at 89.1 mph, though its in-gear acceleration is lustier than these numbers suggest. Indeed, the Turbo has the power delivery that the base Veloster should have had in the first place, especially as its EPA fuel economy (26 city/38 highway mpg) still pips that of the Scion (22 city/30 highway mpg). It'll come to a halt from 60 to zero in 126 feet — not bad, but then its tires quickly succumb to hard driving-induced heat.
Our test car was equipped only with the $2,500 Ultimate package which includes useful bits like automatic headlights, a nav system with rearview camera and back-up alerts. It is unfortunate that a headroom-eating, chassis-flimsifying panoramic sunroof is larded into the package's mix as well, but there's no denying that this Veloster Turbo offers a more formidable features list than the relatively spartan FR-S.
The Dangers of Spec Sheets, Part Two
Just as the Veloster's slalom result prompts a "yeah, but," so, too, does the FR-S drag strip performance. The FR-S ran to 60 in 6.6 seconds (6.3 with 1 foot of rollout) — more than a second quicker than the Veloster — and did the quarter-mile in 14.9 seconds at 93.1 mph. It would be easy to attribute this performance chasm to the 176-pound lighter curb weight of the FR-S and call it a day. But in running both of the cars in our test over hill and dale, the difference in their ability to sprint between corners just wasn't that vast.
Torque is the reason. The Veloster has it and, well, the FR-S has a big dip in middle of its torque curve. As such, achieving the FR-S's acceleration numbers above takes a 5,000-rpm, dropped-clutch, tire-spinning launch. This damn-the-torpedoes launch hazes the tires until just before the 1-2 upshift, which keeps the normally aspirated 2.0-liter flat-4 on boil and bypasses its torque hole entirely. Any other type of launch and the FR-S's 0-60 and quarter-mile times suffer dramatically. Conversely, the Veloster has the torque but not the traction — it's effectively got one tire at the wrong end of the car to handle the launch, and this hampers its ability to perform a holeshot, hampering its numbers.
More thrust in the midrange would only enhance the inherent handling attributes of the FR-S's rear-drive layout. As it is, its 151 lb-ft in the 2.0-liter mill is just not enough poke for when you want to, say, intentionally upset the chassis and induce a sustained powerslide on dry pavement. It is a smooth power plant, however, and is totally at home when the tach needle is flirting with the 7,400-rpm rev limiter. It doesn't sound very good — beyond a bit of intake honk at wide-open throttle, this flat-4 is a fairly agricultural noisemaker. Granted, the Veloster whooshes like a yard appliance at full whack, but at least it falls silent while cruising.
All of this is a long way of explaining that despite the numbers, the Hyundai doesn't really cede any straight-line giddy-up to the FR-S when playing cat-and-mouse on our canyon road. The Veloster's midrange-rich brand of shove is more useful in day-to-day driving, too.
Sporty Vs. Sports
We came away from the Veloster Turbo disappointed. It's not a convincing sporting proposition, rather a package that trades heavily on its funky styling and unusual asymmetry. We want to believe that the Veloster Turbo would brighten up substantially with better tires and a limited-slip differential, but more likely the low-rent beam-axle rear suspension is at the root of the Veloster's dynamic shortcomings, and not even the most exotic concoction of carbon, silica and gears will help it.
The Scion FR-S is quickly becoming the default choice when cost and fun are the priorities. By nailing the fundamentals of the package, the Scion has shown that engaging dynamics need not be out of reach of the common man, and in doing so has put other automakers on watch.
The rear-drive dogma is rooted in truth. The Scion FR-S wins our comparison test.
Fastest N/A tC @ NSS New BEST (1:14.710)
BOOSTED Time @ NSS 1:10-1:11 Unofficial
Music City Scions
Original Gangsta
PTuning Sponsored
Built Motor Fund has began...
rhythmnsmoke is offline   Reply With Quote
Old 07-31-2012, 02:11 AM   #2
TheQuietThings
Super Moderator
SuperMod
TheQuietThings's Avatar
TheQuietThings 25/M
yourfearlessleader HachiRoku1987
WINNING
Chris | 2013 Scion FR-S 6sp manual | Team ScioNRG
www.teamscionrg.com
ScioNRG Facebook Page
Interested in starting or joining a chapter? Send me a message!
TheQuietThings is offline   Reply With Quote
Old 07-31-2012, 02:17 AM   #3
08bspxb
08bspxb 113/M
Send a message via AIM to 08bspxb Send a message via MSN to 08bspxb
Speed3, 21 out the door 263 hp
Sent from my dizzLe using RaWr powers!
http://scionmilitia.com
Mods:
HKS axle-back (with resonator replace), Tanabe DF210 springs,Tanabe strut brace,TenzoR CAI,Greddy 480g shift ****,Black headlight mod w/ squirrel finder mod,6000k 55w headlights,3000k 55w fog lights,tinted reverse light and mirror signals,TRD bumper inlet
08bspxb is offline   Reply With Quote
Old 07-31-2012, 02:28 AM   #4
TheQuietThings
Super Moderator
SuperMod
TheQuietThings 25/M
And your comment has nothing to do with this thread.
Old 07-31-2012, 02:30 AM   #5
Roller_Toaster
Roller_Toaster's Avatar
Roller_Toaster 27/M
lasunbird86
does the speed 3 have IRS? (not familiar with mazdas)
Nikon Squad - D7000
Roller_Toaster is offline   Reply With Quote
Old 07-31-2012, 03:28 AM   #6
dropzone
dropzone's Avatar
dropzone 29/M
No RWD, no care. Why do people bother comparing FF with FR cars? lol
Sometimes to win an argument, means losing the bed.
Upgrades: Agency Power Exhaust
RS 5.0 tC Roll Call
NEVER FORGET ROSA PARKS
dropzone is offline   Reply With Quote
Old 07-31-2012, 07:31 AM   #7
sciontc_mich
sciontc_mich 113/M
^^ because they haven't really driven a FR (front engine-rear drive, for the newbies) car before. It's a completely different way to drive. wait til they encounter OVERSTEER with a rear drive car, something they don't see on FF vehicles. Not normally. I feel sorry for those who will have an accident when the tail gets "happy" and comes around to "say hi".. lol correct the way you with with FWD and you'll end up hitting something or someone. It's a completely different world. I hope those who get the FR-S don't go out and think they're starring in fast n furious 10 (or whatever number they're on now, lol).
Back to the review.. I wondered about the chassis stiffness/quality of the Veloster when I saw that torsion beam-axle, sad, I thought we left that old technology in the past? Also, when I saw the subframe under the veloster, it was not beefy, such as the tC or the FR-S! I think Hyundai is still not up to prime time, but they are definitely getting there! I think Toyota put much more effort (along with Subie's help, dont forget them), than Hyundai did. I do think the FR-S could have more power, but remember the "newbies", kind of wondering if Toyota left it at 200hp and 151lbs torque to prevent more newbies hurting themselves..
sciontc_mich is offline   Reply With Quote
Old 07-31-2012, 07:03 PM   #8
GenomeTuning
GenomeTuning's Avatar
GenomeTuning 24
genometuning GENOMETUNING
Quote:
Agreed lol they need to do a genesis coupe 2.0T vs the FR-S not the Veloster, even thou it is a sweet looking car.
Genome Tuning: Facebook | Twitter | Blog
GenomeTuning is offline   Reply With Quote
Old 08-01-2012, 12:38 AM   #9
rhythmnsmoke
Music City Scions
rhythmnsmoke 4/M
Quote:
That review has already been poste as well.
Music City Scions
Original Gangsta
PTuning Sponsored
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
finder, frs, ptuning, resonater, squirrel, turbo, veloster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
