Register Forgot Password?
Reply
Old 09-21-2012, 04:05 PM   #1
Exclusive_WolF
Exclusive_WolF 19
Default Keep Blowing tail light fuse ? HELP :(
I bought some after market tail lights the LED ones and when i connected it to try it then turn it on the fuse blows . Its the Tail fuse , any idea what this could be?
Please help
Exclusive_WolF is offline   Reply With Quote
Old 09-21-2012, 04:26 PM   #2
TeeCizzle
TeeCizzle's Avatar
TeeCizzle 52/M
Did you rotate the plug into the connector?
IF you blow a Fuse all you need to do is rotate it and plug it back in.
Try that!
TeeCizzle is offline   Reply With Quote
Old 09-21-2012, 09:54 PM   #3
Exclusive_WolF
Exclusive_WolF 19
Try that!
Thanks for the responce but it only goes in one way its just a plug and play tail light you cant really flip it :/
Old 09-21-2012, 10:40 PM   #4
TeeCizzle
TeeCizzle's Avatar
TeeCizzle 52/M
Quote:
Can you take pics of the Connectors??
What kinda of Tails did u get anyways??
Old 09-22-2012, 12:55 AM   #5
testa422
testa422's Avatar
testa422 29/M
that happened to me when i put my new anzos in...come to find out i had pinched one of the wires against the body of the car when i was sliding the new lights in so everytime i turned them on the fuse blew...easy fix!
Become one of us by becoming none of us
testa422 is offline   Reply With Quote
Old 09-22-2012, 02:27 AM   #6
deez
deez's Avatar
deez 25/M
My new anzo's are doing this now too. FML, i gotta take them out and see what I come up with tomorrorw
Built by me. Bought by me. Not sponsored by mommy and daddy.
deez is offline   Reply With Quote
Old 09-22-2012, 08:09 AM   #7
AnotherDude
AnotherDude's Avatar
AnotherDude 33/M
Plug and play or not, you should just be able to flip the led connector. Led tail lights are polarity sensitive, they can only go in one way otherwise you blow fuses. Check the connections again. You should have 3 connections that go into one harness, reverse, brake and blinker
AnotherDude is offline   Reply With Quote
Old 09-22-2012, 09:38 PM   #8
Exclusive_WolF
Exclusive_WolF 19
Thanks for the prompt responces guys i have auzo aftermarket tail lightsbif that helps here a picture of the connection if it helps let me know !
Old 09-23-2012, 07:17 AM   #9
dropzone
dropzone's Avatar
dropzone 29/M
That connection can only hook up one way. It's the other connection with the green wire and one has a stripe(if I recall, installed mine a year ago), match those up correctly and you should have no problem. Before connecting anything I checked how the wires were colored, haven't had any issue. May you get this figured soon.
http://anzousa.com/support/pages/led...n/tC_0507.html
As it says in the instructions, "make sure to match the ground to ground."
Sometimes to win an argument, means losing the bed.
Upgrades: Agency Power Exhaust
RS 5.0 tC Roll Call
NEVER FORGET ROSA PARKS
dropzone is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
06, 2005, anzo, blowing, brake, dome, fuse, lamp, light, location, relay, scion, tail, taillights, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
