205/65/15 on stock steelies?
Old Oct 11, 2012 | 02:19 AM
ufvj217's Avatar
Default 205/65/15 on stock steelies?
I looked through the sticky thread but didn't see anything. It may have been asked before, but I would like to confirm as I plan on getting new tires tomorrow. I saw on another forum that some guy was running 205/65/15s on the stock wheels without rubbing, it just made the xb sit a little higher. will these fit? I'd like to get the biggest I can without rubbing. Preferably 205s.
Also, right now new wheels aren't an option, so I have to stick with the stock ones.
Thanks!
Old Nov 12, 2012 | 10:19 AM
fuad1907's Avatar
Thanks!
Hi
The stock recommended size (for both front and rear) is 185/65r15 88s so the Stock Revs per Mile is 850.3
If you go with 205/65/15s, then Diameter Difference: 4.05% from stock that would create revs per mile to be 816.2.
When the Actual speed is 60mph or 100kmph then speedometer reading will be using 205/65/15s will be 57.5 mph or 95.9 kmph. So the Speedometer Difference is 4.203% too slow. So you calculate your fuel consumption based on Speedometer will not be accurate. So It is recommended to be within 3% of diameter difference. SO you can use 205/60/15 or 205/55/15.
Old Feb 11, 2013 | 02:37 AM
motogeezer's Avatar
Yea, but do they rub?
Old Feb 27, 2013 | 02:02 PM
trktwo's Avatar
ditto
Old May 9, 2013 | 03:35 AM
biancoxb's Avatar
Sorry for the late reply, but yes I have been running falken ziex 912 for almost two years 195/60 wider wall, smoother ride, better look!
Old Oct 6, 2015 | 03:48 PM
xxRayTardedxx's Avatar
Default 05 Scion xB tires
205/65/15 rub in the front at full turn. Rear tires no issues. I made them work by trimming the plastic around the rub. If possible go with a 195/65/15 they seem to the perfect fit for the car.
GoodVibes
Apr 8, 2015 05:30 PM
SloTC1
Apr 2, 2015 07:11 PM
SuBSiN
Mar 13, 2015 04:02 AM
mischman
Jan 14, 2015 06:07 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
