Lowest mileage record?
Old Oct 11, 2012 | 07:21 AM
xb27's Avatar
Default Lowest mileage record?
My 2012 xB is a year old tomorrow, I'm taking it in for it's second Oil change at 4800 miles
Is this low amount of miles in a year a Forum record?? Anyone done less?
Old Oct 11, 2012 | 10:27 AM
TheQuietThings's Avatar
im sure there are trailer queens and show cars out there that dont get driven that have much less
Old Oct 11, 2012 | 12:33 PM
criminaltc's Avatar
I'm more focused on the "second oil change at 4800" comment. That first batch of oil you are always going to want to leave that in a brand new engine. You should never be quick to change it the first time. It is very important that the same oil works and breaks down in a new daily driver engine. You want the same oil to work with the internal components at least the four to five thousand mark even though you don't drive it that often and you probably changed it because the "date' came up before the "mileage".
Old Oct 11, 2012 | 01:20 PM
Roller_Toaster's Avatar
my 09 is only at 112k. :D
Old Oct 11, 2012 | 04:51 PM
xb27's Avatar
criminaltc : Good comments, however, my Wife's car Engine failed and needed to be completely replaced, under warranty last year, $7500 ( 2006 VW Convertible), we bought it new from the Dealership and it was always serviced/maintained by them. It was a VW warranty and the first thing they asked for were maintenance records and an Oil sample. Of course everything checked out OK, they could find no cause not to pay up.
Scion recommend 5K mile or 6 months Oil changes, so I'm just following their guidelines in case the same thing happens to the xB, the Dealer keeps the records so they have no argument.
Old Oct 11, 2012 | 04:54 PM
xb27's Avatar
Wow!!!! Just curious, have you had any problems since you owned it?
Old Oct 11, 2012 | 05:43 PM
scottzj's Avatar
I have an 08 with 22k on it. Of course I am pounding tons of miles on it lately, so will not be this low for long!
Old Oct 11, 2012 | 07:02 PM
AAG's Avatar
AAG
DeepSouth Scions
A 2012 collecting dust & poop on the dealer lot with 10 miles.
Old Oct 11, 2012 | 09:05 PM
aryan13's Avatar
Old Oct 12, 2012 | 02:04 AM
jetas's Avatar
My 2012 has 10,400. Just took it in for the 2nd oil change last week
Old Oct 12, 2012 | 02:51 PM
I had to replace my passenger side axle...but it IS very low.
Other than that..my clutch master cylinder just went out for no apparent reason...but that's pretty much it!
Old Oct 12, 2012 | 06:25 PM
LophatXB's Avatar
Have to say I didn't have a trailer queen,and I did cruise mine often, but before I crashed my Super White, which was an 09. This past March it had only 12,308 on it and I purchased it in June of 09. I might win.
Old Oct 12, 2012 | 09:51 PM
sp2's Avatar
sp2
Defined3
what symptoms did you have to warrant you changing these??
having a little transmission sickness just havnt had time to take it up to shop
Old Oct 12, 2012 | 11:10 PM
For the passenger side axle, the boot seal was torn, and grease was everywhere. For clutch M/C, brake fluid everywhere under car, no visible leaks from brake master cyl, or clutch slave cylinder, also, clutch pedal would "suck" itself onto the floor.
Old Oct 13, 2012 | 01:02 AM
vancouverray's Avatar
2012 xb 8500 miles or 14000 km . Took delivery aug/10 2011 . No problems .
Old Oct 17, 2012 | 03:49 PM
karenew1's Avatar
2012 release series, took delivery 4/31/12. Just hit 2200 miles.
Old Oct 17, 2012 | 04:23 PM
DJ_FroZone's Avatar
2010. started off lot with 300. currently at 57k
Old Oct 18, 2012 | 06:53 AM
TrevorS's Avatar
My 2008 is still under 1300Kmi.
Old Oct 18, 2012 | 04:51 PM
sp2's Avatar
sp2
Defined3
13 hundred thousand??
Old Oct 18, 2012 | 08:09 PM
GQQSE13's Avatar
my buddy matt has a 1st gen xb (06 maybe?) that i think just hit like 15k miles this year (helps that he worked across the street from his apartment lol)
