19X7.5 +45 offset
Old Feb 14, 2004 | 08:29 PM
quadoptix's Avatar
Default 19X7.5 +45 offset
anybody know how this will fit? also, anyone have any pics of cars w/ this particular setup? I'm just wondering. I know this isnt a good offset, but ill space it out.
Old Feb 15, 2004 | 02:43 AM
EMU's Avatar
EMU
you might have to space it out quite a bit i have 19's and put a 5mm spacer its on a +42 offset it still sits a little in its noticable if you stare at it from the rear, also it might rub +45 offsets are usually ran on hondas, try to find like a +38 offset and you can still run a spacer if needed ill try to pm you some pics bro
Old Feb 15, 2004 | 02:46 AM
EMU's Avatar
EMU
look at the 5 zigen post on this forum he has a +25 offset its flush
Old Feb 15, 2004 | 08:34 AM
EL_PAALO's Avatar
Those are 7" wide though. The same look with a 7.5" would require an offset of +31mm.
Old Feb 15, 2004 | 10:15 AM
quadoptix's Avatar
Default thanks
thanks for the respond...i know what the ideal offsets were regarding wheels, just wondering if the +45 would rub or not....its a particular wheel im getting a crazy deal on =)
Mike
Old Feb 15, 2004 | 10:22 PM
EL_PAALO's Avatar
If it rubs, get spacers.
Measure to see if you have the extra 32mm towards the struts/springs from the stockers.
Old Feb 15, 2004 | 11:33 PM
quadoptix's Avatar
Default yeah..
thanks i know that =P i was seeing if a +45 would rub
Old Feb 21, 2004 | 12:58 AM
Kendo's Avatar
Default 19×7.5 ET45
I'm thinking this will rub.. if not you will be a hair away from rubbing in the rear. Inazuma was running an 8" wide wheel with ET42 and it rubbed. He needed a 3mm spacer in the rear to barely clear. According to my calculations, an 8" wide wheel ET39 and a 7.5" wheel ET45 sit the exact same distance from the strut housing. I know that even with the spacer, Inazuma had soem rubbing during turns so you'll probably have to run a 5 mil spacer to be sure. The wheels will still look tucked under. In fact, if you get 18×7.5 ET25, they'll look just as big as 19×7.5 ET45 since the wheels will sit ¾" further out to the fenders...
Old Feb 23, 2004 | 04:58 AM
scionxb04's Avatar
running 18x7.5 with 45mm offset....no rubbing in the front....and used a 5mm spacer in the back because i felt the tire was to close to the rear crossmember....i did drive the car for awhile without the spacers without problem.....after lowering the car with tein s tech's i used 5mm spacers in the back.....all is well
Old Feb 23, 2004 | 05:11 AM
quadoptix's Avatar
thanks for the response guys. I was checkin cause the rim style i like comes in that setup, but the ones im ending up getting is a 19X8 +37 offset....thanks again guys
Old Feb 23, 2004 | 05:18 AM
matchbox's Avatar
Default 19x7s
I just put some HP Racing 19x7s with a +42 offset running Yokohama Prada Spec IIs 215/35-19s. They are inset just a little but lucky for me that is what I need ti tuck my tires with my bags. They will rub with a 2" Goldline drop. Yo need to trim the fender liner and knock in the medal fender some, but not much.
https://www.scionlife.com/?matchbox
Matchbox
Dave[/url]
xBrelease08
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
