Sunroof stuck on one side..
Old Mar 30, 2013 | 05:20 AM
RacingHart_XA's Avatar
Default Sunroof stuck on one side..
I searched for any info on how to fix this. It might be from the winter frost? Anyways, the sunroof is stuck on the driver side. I tried to push it up, but it won't budge. What can I do besides take it in to the dealership?
Old Mar 31, 2013 | 03:57 PM
criminaltc's Avatar
If you think it is weather related, bring it into a garage and let it get to room temperature. Or take a heat gun (keep it far far away when applying heat) and heat it up that way. Otherwise, how is it stuck on one side? What are you noticing that is making you think that? Is the passenger side a bit farther back because it is attempting to open, and the driver's side is staying? Is that was it happening? Well if that is what is happening, that's not that big of a deal because it is one motor that pulls the whole window open so at least that is working. I doubt something came off track though. If you find that it is not weather related, then you are going to have to take the headliner off and pull it all apart to see what is not turning or spinning. I'd get my fingers in there and pull it open while someone pushes the button. If that's not working, then there's something much worse going on. That whole mechanism is not very difficult to understand, so once you are seeing it, you'll know what you have to do, it's exactly like a door.
Old Mar 31, 2013 | 04:25 PM
TTCCC's Avatar
When it rains just do this:
Old Apr 12, 2013 | 01:37 AM
the top can open, but the only the passenger side opens up. i cant slide the sunroof outward cause the driver side is stuck and wont budge. the motor works if its opening the passenger side so maybe the driver side mechanism is stuck somewhere.
Old May 6, 2013 | 08:14 PM
jiles25's Avatar
Try some WD-40 my roof used to close only halfway then get stuck and open back up so I would have to put pressure on it when I closed it to close all the way.
I sprayed some WD-40 and the tracks and wheels and it closes fine now.
____
Old May 6, 2013 | 09:17 PM
Alvinio87's Avatar
Coolest thing ever
Old May 14, 2013 | 11:09 PM
sciontc_mich's Avatar
^^ IT looks like it has a beanie hat on!! hahahaha
have you tried to lube both sides of the sliding track with a little silicone spray??
Old May 15, 2013 | 01:33 AM
etoomey3's Avatar
LOL. Classic! Havent seen that pic in a while. Use silicone spray or silicone grease that you can apply with a brush. And heat it with a hair dryer not a heat gun.
Old Dec 9, 2019 | 02:38 AM
Ariel818's Avatar
That just happened to me today on my 08 tC.
What should I do?
____
Old May 9, 2020 | 09:45 AM
Reddoxx's Avatar
lube the track and spray some PB Breaking fluid on the sunroofs wheels that ride in the track. they might be seized up...
three_percent_hero
Scion tC 1G Aero & Exterior
36
Jan 28, 2022 07:22 PM
BurntClutch
Scion tC 1G ICE & Interior
May 11, 2016 02:29 PM
tjbartjr
Jun 16, 2010 09:34 AM
zzzBrett
9
Apr 25, 2008 11:18 PM
scionfreak1986
Sep 23, 2005 03:10 AM
