DIY: PNP HID projector retro fit
Old May 3, 2013 | 05:33 AM
bcpzx3's Avatar
Default DIY: PNP HID projector retro fit
Here is a plug and play type HID projector made to fit cars that use H4 type headlight bulbs.
I say plug and play because it is made to fit into the headlight without any cutting or drilling.
Note: You still need to bake your headlight to remove the lens in order to install the projector.
I will actually be selling these specific set for $400 shipped w/ the HID bulbs and ballast, will need custom wiring to make the Bi-xenon hibeams work properly.
Total install time - 2hr from start to finish
All stock
Stock headlight beam
Projector and HID bulb/ballast laid out
Headlights removed and into oven
Bake for a few minutes at 250degree Fahrenheit
New projectors installed and ready to go
Slightly blue color due to 35watt ballast with 6000k bulbs.
Old May 15, 2013 | 04:21 AM
eignub's Avatar
is that the kit from the retrofitsource? i got the same if it is, and it works pretty good, it seems like the output is lower then stock, but im not sure since i haven't had stock ones for like two years or so.
yoson13
Scion xA Aero & Exterior
13
Aug 29, 2015 11:12 PM
Basebllstar
Jan 8, 2015 12:30 AM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
