Help on How to make speaker mount
Old Apr 12, 2005 | 10:25 PM
Eastwick's Avatar
Default Help on How to make speaker mount
I need some help on how to make the speaker mount for my xb. i dont know if the factory mount could be use.
Need some help on this.
Old Apr 13, 2005 | 02:48 AM
neckbonenick's Avatar
The factory mount can't be used if you have normal sized magnet. If you don't want to make your own trim ring like this from 3/4" mdf. You could look for a set of components with neodymium magnets. I think diamond audio or image dynamics makes some.
Old Apr 21, 2005 | 05:18 PM
2azfe's Avatar
dude did u use a rivet to install ur speakers in? what size of rivet should i use?
Old Apr 21, 2005 | 05:31 PM
no I just used 1" drywall screws
Old Apr 21, 2005 | 05:45 PM
2azfe's Avatar
1" dry wall screws? u actually used screws to install the mdf board to the door? hmm... i did not thought that it would fit in...
Old Apr 21, 2005 | 07:53 PM
of course it'll fit. 1" into 3/4" mdf it prolly 1/8" sheet metal gives you only a little nub in the back.
Old Apr 21, 2005 | 08:10 PM
drywall screws are not meant for metal try sheetmetal screws , i'd be afraid theyd come loose.
Old Apr 22, 2005 | 12:18 PM
2azfe's Avatar
i think the best thing to do is to rivet it in... i am using sheet metal screw right now that came into the spacers that i bought form circuit city (plastics ones) and now i can hear them rattling and vibrating after a week of installation. thats why i wanted to do a spacer from mdf but i dont know what size of rivet i should use to put in... does anyone have an idea on this?
Old Apr 22, 2005 | 01:37 PM
squarepants's Avatar
it's simple just drill out the rivets and cut out the old speakers,you can use a hacksaw blade it's just hard plastic,place your new speakers in the mount and screw them on,i was a lil lazy so pull back the plastic on the door and screw the mounts with some nuts and bolts can't remember the size doh,anyway my infinity looks and sounds great good luck...........
Old Apr 22, 2005 | 01:42 PM
i think if you use rivets and have to change your speakers in the future(blow speakers)you got to do it all over drill and rivet,drill and rivet too much work for me....
Old Apr 22, 2005 | 02:04 PM
cadaver's Avatar
just remember, do the job right the first time, don't half-acre the work. it doesn't matter if youre a professional installer. research the job first, check out some install sites and do a little extra work the first time so you dont have to do it the second time. Remember, the lazy man works twice as hard!
Old Apr 22, 2005 | 02:34 PM
2azfe's Avatar
i dont want to screw up my stock speakers... if i did and wanted to go back into all stock then its gonna be a problem... i prefer doing it the proper way for me to also learn the how to's on doing it...
Old Apr 23, 2005 | 12:35 AM
Dr_Isotope's Avatar
They're called "binding barrels and shoulder screws" Availaible at any Home Depot/Lowe's, etc. Use them in the original holes to attach your new baffles. 10/24 or 10/32 will fit through the OEM rivet holes, 1/4x20 will require them to be drilled out slightly.
They can easily be removed, and require no special tools to install. Many are simply slotted heads, and can be annoying to work with. Look for hex headed models, which may costs a few cents more, but will save a world of hassle.
Old Apr 23, 2005 | 02:58 AM
mine never rattle. Whats the big deal?
Old Apr 24, 2005 | 05:09 AM
nuts and bolts work great for me no rattles and less headache,if want use the rivet method that's your choice i just think the nuts and bolts method was just a easier and simple way to do it,if my speakers had rattles i won't suggest it in the first place....
Old Apr 24, 2005 | 05:17 AM
hey neckbonenick lets sit back and check all the hi-tech skills on how to install front speakers on the xb made so difficult..........
Old Apr 24, 2005 | 03:09 PM
squarepants Posted: Sat Apr 23, 2005 10:17 pm Post subject:
Man I know. This isn't rocket science.
clickclickw00t
Feb 18, 2015 08:57 PM
Erickdimas7
Scion tC 2G ICE & Interior
Jan 16, 2015 03:41 AM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
rancur3p1c
Scion tC 1G ICE & Interior
Dec 21, 2014 09:23 PM
