Offset Calculator!
Old Feb 17, 2004 | 10:38 PM
stankubrick's Avatar
Default Offset Calculator!
http://tools.ecn.purdue.edu/~krausej...offsetcalc.xls
I found this on the 7thgencivic.com forum. Created by Boilermaker1.
This is for people like me who get all confused about measuring wheel fitment. All you need is rim width and offset, then just plug and chug.
*For use just as a guideline.
**Real world measurements vary by manufacturer.
For reference:
stock steelies: 5.5" width, +38 offset
flush rims: 7" width, +25 offset (taken from 5zigen Inperio)
hope this helps some people....
EDIT:
flush rims (front): 7" width, +25 offset
flush rims (rear): 7" width, +15 offset
stock steelies: 6" width, +38 offset
Old Feb 17, 2004 | 11:11 PM
bBted's Avatar
u can use it as reference...but its not always accurate...
7"width offset +25 is flush in the front...the rear u can use +20 or even +15 instead
Old Feb 17, 2004 | 11:23 PM
quadraphonic's Avatar
I noticed that on my echo as well.. looks like a lower offset, or wider rims are needed to bring them out in line with the fender flares.
Old Feb 17, 2004 | 11:25 PM
Opr8r's Avatar
Teddy is right.. I would even say that the offset for a 7" wide wheel should be +20 mm to be *totally* flush. There's still a little more room in the front to come out.
Peace,
m@
Old Feb 17, 2004 | 11:27 PM
Hey guys.. something I've been wondering about is strut clearance. Based on the stock steelies (I figure them for 5" wide, 45 offset), how much further in can a wheel go before clearance is an issue. 5, 10, 15mm?
Old Feb 18, 2004 | 04:27 PM
EL_PAALO's Avatar
Here's a simpler calculator:
http://toy4two.home.mindspring.com/offset.html
Remember, if you use a different offset out back, you won't be able to rotate normally. You also need more clearance in the rear when carrying a full load.
Something else to consider is that by going with a wider stance in back, you're adding understeer which you'll probably want to counter with a larger sway bar in back or stiffer strut/spring settings in the rear.
Also, every wheel and tire is slightly different. +25 sitting flush with one wheel might be +27 in another wheel (same width). Same goes for tires fitting - just because tires are listed as the same size doesn't mean they are exactly the same. Some are very different.
Old Feb 18, 2004 | 04:37 PM
sithscripter's Avatar
Default Re: Offset Calculator!
Originally Posted by stankubrick
For reference:
Stock steelies are actually 15x6 ... it's stamped into the rim. But from my own crude measurements the +38 offset seems right.[/quote]
Old Feb 18, 2004 | 06:08 PM
Sorry.. my estimates were based on the echo's steel wheels. Weird though.. we both run on 185/60R15 but my wheels are only 5" wide where the Scions are 6.. hmm.
Old Feb 18, 2004 | 08:37 PM
Originally Posted by EL PAALO
Yeah, this is way better, thanks..it calculates the clearance from stut housing too. :D
Old Feb 19, 2004 | 01:22 AM
EL_PAALO's Avatar
np, and I guess I need to update wheelspecs if the stockers are actually 6" wide.
Old Feb 19, 2004 | 04:18 AM
westsype's Avatar
How about an 8" width what would be flush lets say 17x8 what offset?
Old Feb 19, 2004 | 04:24 AM
EL_PAALO's Avatar
Put 7 in the first box. 25 in the second box.
8 in the third box. you can figure out the 4th box after one try.
xBrelease08
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
