E153 transmission swap info
Old 03-30-2014, 12:37 AM
Music City Scions
BlackKnight's Avatar
Default E153 transmission swap info
I am going to be gathering some prices together for making the parts needed. This is not just buying these brackets and your done. The transmission has to physically be disassembled so after the case is drilled it can be completely cleaned. Very basic run down of whats required:
Transmission E153 (MR2 Turbo - comes LSD if specified, Camry V6 – no LSD)
Throwout bearing MR2 or Camry V6 (For E153)
Make custom shift cable bracket
Make custom rear transmission mount
Modify rear transmission mount bracket
Modify passenger CV axle mounting bracket
Need Camry V6 driver CV axle (only using tripod shell)
Modify driver CV axle (shorten shaft and install tripod shell)
Drill and tap transmission case
Make custom bracket for top of transmission to allow an additional two bolts for mounting
Freeze plugs
Shift linkage from original transmission needs modified
There are always more than one way to do something, I did it this way so all the factory shift cables would work, The Camry and MR2 uses different shift cables and the mount is different on the shift linkage, you could run the linkage that came with this transmission and fight to figure out which cables to run. This is all the info I am putting out. I will have prices soon for brackets and mounts. If you buy these I will take the time to do a write up of what exactly has to be done start to finish.
Swap cost me 2100. I had two gears that needed changed. Place I ordered the transmission from gave me the wrong vin and I wasted 220 on gears that I cant use and had to reorder the right gears.
BlackKnight is offline
Old 03-31-2014, 03:41 PM
BadDudeTC3's Avatar
This is so full of win! If my tranny goes then I'm definitely going to do this swap!
BadDudeTC3 is offline
Old 04-02-2014, 05:06 PM
05rs1's Avatar
This is new to me......what's the benefit?
05rs1 is offline
Old 04-02-2014, 05:30 PM
electrongeek's Avatar
I've heard of the E351 swap, but this is new to me as well. I'm curious.
electrongeek is offline
Old 04-02-2014, 05:37 PM
criminaltc's Avatar
better gear ratios for booster'ds.
criminaltc is offline
Old 04-02-2014, 05:39 PM
Music City Scions
That's partially true but only a little better. This transmission is bulletproof the E350-E351 is the same except the ring and pinion. There both weak transmissions
Sent from my HTC6525LVW using Tapatalk
Old 04-02-2014, 05:51 PM
criminaltc's Avatar
I figured he meant 153 and just moved the numbers around. The 351 has a different final drive that is also better suited for booster'ds, but everything else is the same and just as brittle as the 350 (stock tC transmission). But I was answering his question assuming he was asking about the 153. The 153 is better all around for the BlackKnight is going for... which is crazy power.
Old 04-02-2014, 08:03 PM
Music City Scions
E153 vs E350 still has slightly taller gears. Example 1-4 shift speeds
32
57
83
116
Music City Scions
Stock rev limit
Old 04-02-2014, 10:22 PM
05rs1's Avatar
Do you think it'll improve your ET at the track by just swapping to the E153 tranny?
05rs1 is offline
Old 04-02-2014, 11:06 PM
GUNNIST14's Avatar
Waiting to see the results of this swap. I have a UE-350 on my bench at work waiting to swap in if my stock trans fails when I go boost again. 2100 isn"t too bad granted you'll have more gears.
GUNNIST14 is offline
Old 04-03-2014, 01:35 AM
criminaltc's Avatar
Gunnist, the swap is done homie. Check his build thread.
Old 04-03-2014, 04:08 PM
Music City Scions
Its has approx 600 miles on it. Yes it will slight improve Et vs my old one due to being in boost longer through each gear.
Old 04-04-2014, 01:49 AM
my06tc's Avatar
ill send you my tc and you can do it for me lol
my06tc is offline
Old 04-04-2014, 12:06 PM
Music City Scions
My coworkers back so hopefully within the week we will have prices
Old 04-24-2014, 03:46 PM
burgandybomber's Avatar
Found the right place to be asking questions... I guess im interested to hear what prices would be.
burgandybomber is offline
Old 04-24-2014, 04:46 PM
criminaltc's Avatar
I saw this one after your other one. I think BlackKnight has spent a couple dollars on his build. Haha.
Old 04-24-2014, 07:31 PM
05rs1's Avatar
Well i blew another tranny...this time 3rd gear. So i gotta look into this setup if its working out good
05rs1 is offline
Old 04-24-2014, 08:21 PM
criminaltc's Avatar
It wasn't built was it?
Old 04-24-2014, 08:28 PM
Music City Scions
My original one had cryogenic and rem treatment on everything and still broke at 400whp and wtq
Quick Reply: E153 transmission swap info
