2014 10 Series light up Badges mod?
Old 04-11-2014, 12:19 AM
torranosaurus's Avatar
Default 2014 10 Series light up Badges mod?
I have a new tC 10 Series and am looking to make the front and rear badges stay on when the car is running.
Anyone have any ideas on how to?
___
torranosaurus is offline
Old 04-11-2014, 02:34 PM
Alex_sciontc's Avatar
i have the same question but only when driving at night ? - is there anyway to directly connected to the main lights .
Alex_sciontc is offline
Old 04-11-2014, 06:15 PM
russiankid's Avatar
Trace where the badges get power. Or you can just install a relay and make them turn on from the ACC position.
russiankid is offline
Old 04-11-2014, 06:29 PM
criminaltc's Avatar
Get a test light and fish around for a wire with constant power and BOOM! tap in to that.
criminaltc is offline
Old 04-16-2014, 12:01 AM
jarvasdb1's Avatar
No don't tap into a constant power. Otherwise the power will be on all the time. If you want it to be on during the night time then tap the badge into your parking light (+ blue wire).
Send to PrinterClose Window
2013 Scion tC Parking Lights (+) There are currently no notes for this item.©2012 Directed Electronics. All Rights Reserved.
Click photo to view a larger version
(*** not all photos have a larger version)
jarvasdb1 is offline
Old 04-16-2014, 12:24 AM
What about the resistor in between? Won't it burn out? Does it need bypassing??
Old 04-16-2014, 12:30 AM
jarvasdb1's Avatar
What resistor are you talking about? What is it a part of?
Old 04-16-2014, 12:36 AM
russiankid's Avatar
The whole point of a resistor is to drop the voltage, if you are going to bypass a resistor you will be increasing the voltage to the badge which will burn the badge out.
But as already mentioned, what resistor and where?
Old 04-16-2014, 12:38 AM
I looked at the factory diagrams and all 4 lights have some type of capacitor in the wiring.
Old 04-16-2014, 12:48 AM
jarvasdb1's Avatar
can you copy and paste that diagram?
russiankid's Avatar
Could you post up a picture of the diagram?
Old 04-16-2014, 12:54 AM
I will do it in a day or two. It came in the owners manual as additional paperwork.
Another issue is that the outer lights change from white to blue.
Old 04-16-2014, 12:55 PM
criminaltc's Avatar
You are guys are just like everyone else. Clearly you cannot read. Read this dudes original post. He wants it on all the time, when the car is on.
So what would a person do if they wanted something to have power to it all the time when the car is on? Hmm... probably tap into a wire that has power ALL THE TIME.
Old 04-16-2014, 05:41 PM
jarvasdb1's Avatar
Really? SO go ahead and do what Criminal says so that your lights will be on even when the car is off and parked.
Simply wire it to an accessory or ignition.
____
Old 04-16-2014, 05:47 PM
jarvasdb1's Avatar
OH yeah and I was partially wrong. I don't have a problem admitting that. Enjoy. Guys like you Criminaltc are what can ruin forums.
Old 04-16-2014, 05:56 PM
criminaltc's Avatar
Constant power with ignition to the "on" position. Not a wire that's always hot... come on...
Old 04-16-2014, 07:25 PM
jarvasdb1's Avatar
sorry but wasn't specified. Can't expect someone to know exactly what you're thinking. But 12V+ with key on can either be Accessory or Ignition. Constant is constant whether the car is on or not. Sorry, I was reading into it as an installer. But that's my point. Just like you said don't be vague. I'm on this forum to learn and to teach when I can. There are times that I have been corrected due to misinterpretations and I myself have corrected people. It's a part of being human. Let's try to keep this friendly and informative without being judgmental.
To Torranosaurus use this as a guide. Always test wires before making connections. Ignition gray wire white 8 pin plug pin #6 at ignition switch, can also use Accessory black wire pin #3 at same location. Good Luck
Old 04-16-2014, 08:00 PM
criminaltc's Avatar
Thanks for being level headed. We're good now.
Old 04-16-2014, 10:16 PM
jarvasdb1's Avatar
Good to know. Thank you.
Good luck figuring out the lighting setup Terronosaurus. Post up your findings.
Happy Modding.
Old 10-15-2014, 03:51 AM
F4htata's Avatar
any updates on this? i wanna know if this is possible.
F4htata is offline
Quick Reply: 2014 10 Series light up Badges mod?
