Serpentine belt noise?
Old 04-16-2014, 04:41 AM
TrevorS's Avatar
Default Serpentine belt noise?
Got just over 13K on my 2008 and am noticing at idle there's a sound like a squeaky belt under the hood. Anybody else notice this?
TrevorS is offline
Old 04-16-2014, 12:31 PM
FlintMica17's Avatar
When does the noise happen? Cold starts? After you have been driving? Is it a constant "sqeeeeeeeeeeeak" or more like a " squeak, squeak, squeak, squeak"?
FlintMica17 is offline
Old 04-16-2014, 01:06 PM
criminaltc's Avatar
Props on the low mileage. And yeah what Flint asked.
criminaltc is offline
Old 04-19-2014, 04:14 AM
TrevorS's Avatar
Occurs after short mileage, yeah like a mile or two. Can't see how it would be more serious than a belt squeek, but not personally used to hearing anything much at all other than lifters and such. Standing in front of the idling engine, the sound seems somewhat broad rather than left/right or where the belt is. Any thoughts?
TrevorS is offline
Old 04-22-2014, 10:01 AM
criminaltc's Avatar
No, it's not broad. A squeak is going to be a belt only, and nothing else. Regardless of your mileage, the belt is still six years old, and actually, the fact that the belt hasn't been worked out too much might have something to do with it. But a squeak for a few moments on a new start is alright. It is an indicator that you will need to replace the belt, or a pulley, or water pump eventually. I'd take it to the dealer and have them scope it out and tell you what's wrong. They will pin point it in two seconds.
Old 04-22-2014, 08:03 PM
xbscion's Avatar
I would first buy a new belt, check the tension pulley, water pump for play, then take it in to the dealer if the noise is still there.
xbscion is offline
Old 04-23-2014, 11:32 AM
elwaylite's Avatar
I put about 75k on our first belt before I changed it this year with a new Gates. Quiet as a mouse the whole time though.
elwaylite is offline
Old 05-04-2014, 01:19 AM
TrevorS's Avatar
Thanks guys! I inspected the general belt area and there is no sign of any kind of leak, pink line, low coolant level, etc. Even pan oil level is good. Belt tension seems ok to hand pressure and the squeaking only shows up during warm idle. I'll have to see if I can localize it with a stethoscope. Suppose I could also try releasing and reapplying the tensioner. Has anybody heard of tensioner problems with these 2az-FE engines?
TrevorS is offline
kb1sxv
10-21-2015 05:00 PM
olyellr
09-28-2015 10:32 PM
Klashan
09-24-2015 12:39 PM
Ksn
09-21-2015 06:21 PM
mcnick0495
Scion tC 2G ICE & Interior
09-08-2015 02:58 PM
Quick Reply: Serpentine belt noise?
