Creaking Noise
Creaking Noise
Noticed this noise when the radio is off, creaks when driving slowly and turning the wheel, will change to different springs if this continues dont know whats wrong have trds installed now, 2012 scion tc, any mistake i could have done while changing?????
did u keep the dust guard? (black rubber thing that goes around the strut and sits on top of the spring)
that usually keeps the springs quiet.
also i hear from people that the trd springs need to be installed in a specific direction, make sure ur driverside is in the correction setting
umm lol i dont remember a dust guard, i dont remember seeing one when taking it apart and had no boots lying around after so the car doesnt have any I guess do they come with it lol, and do you have the correct instructions for the setting of the spring.
I've had this creaking since I put in my spring over 35k miles ago. These is a rubber o-ring between the two layers of the top hats, I believe they're the culprits. I haven't bothered to fix it as it has not got any worse.
Check all the bolts make sure everything's tight. Not sure Wat ur issue is. Did u mark the strut top so everything went back together lined up ? I have zero creaking and I didn't bother greasing anything. Prob out 2000km on them now.
I think if there was a way to tell you wouldn't have to mark it. It seamed like it was totally flat to me but maybe something to do with it only suppose to turn 1 way or other. Does it make noise when you turn both way or just 1. If only creaks wen turning left I'd unbolt the 3 drop it and just reach up in and rotate to the left so the front most bolt goes to the rear most hole. Or vice versa if it only does it to the right. If it does it both ways is still give it a shot. Is it only 1 side of the car or both?
Klashan
09-24-2015 12:39 PM
Andreas24
09-15-2015 02:10 PM
BlingSlade
09-05-2015 08:52 AM
