turbos, exhaust, intakes
tC: Turbo Kit- Mostly Complete TC1
Old 01-15-2017, 11:46 AM
skruff's Avatar
Default Turbo Kit- Mostly Complete TC1
Located in LA.
Descendant turbo kit
Was on an 06. Don’t recall if there is a difference between 05/06 and 07+
Have most of the parts. Missing s-pipe and downpipe since the bolt broke and I couldn’t get them off the car. You should be able to use another brand although then my base maps will not work for you and you will have to get a tune (although you should get a tune anyways).
Nipple on turbo going to wastegate is chipped and will need to be replaced. You will need to purchase an oil return line. Steel clutch line also included- I could not get my OEM one off. Purchased a replacement hard line in case it cracked when I went to try and install again but never got around to it. Oil pan is untapped although you can easily add the spout since it is not mounted to the car. RC 750 cc injectors with pnp clips. AEM FIC “boomslang harness” was made by me- it has resistor mod. Intercooler has dent on the bottom of it. Prosport boost and oil pressure gauges, along with electronic senders and oil filter plate. Also including turbo heat shield and AC line wrap.
I have a ton of information to give with it as well- install instructions, pictures, base maps, and I can answer any questions after the sale (that I can answer without extensively digging into). I was in the buyer’s position once and wished I had all of this information.
Dyno’ed at 280 although my OEM clutch started to clip so they stopped there. This kit is supposed to run 320 with a good tune.
Little to no turbo spindle play. I took a video for verification. If you are interested, I can send that to you.
$1,300 OBO. Can ship but you have to pay shipping. Will part out if there’s enough interest although I doubt so since the forum is so dead.
More/larger pictures located here:
https://drive.google.com/open?id=0B1...0NlcmRLckJZWEE
Attached Thumbnails Turbo Kit- Mostly Complete TC1-1.jpg   Turbo Kit- Mostly Complete TC1-2.jpg   Turbo Kit- Mostly Complete TC1-copy-dyno-sheet.jpg
skruff is offline
Old 01-19-2017, 04:46 PM
bbsciontc's Avatar
Hey Skruff. Try selling this on the Facebook pages. "Scion tc1 parts for sale". Lot's more traffic and will probably go quickly.
Good luck.
bbsciontc is offline
Old 01-20-2017, 01:58 AM
skruff's Avatar
Thank you BB.
skruff is offline
Old 05-01-2017, 05:54 AM
stahsin96's Avatar
do you still have this?
stahsin96 is offline
Old 05-04-2017, 07:41 AM
Administrator
Administrator
MR_LUV's Avatar
bump
MR_LUV is offline
Old 11-28-2017, 10:50 PM
Boostedtc_76's Avatar
U still have the RC 750 cc injectors with pnp clips and AEM FIC with the boomslang harness? How many PSI were you running with this kit? thanks
Boostedtc_76 is offline
Old 11-28-2017, 10:51 PM
bump
Old 03-19-2018, 04:46 AM
deficientc's Avatar
are the injectors still available?
deficientc is offline
