Block Guard, Do I really need this ?
Old 01-30-2017, 04:47 AM
taoybb's Avatar
Default Block Guard, Do I really need this ?
I already search through forums and goolge about this thing but still not get a quite clear answer. Some people said not neccessary but some said must have this.
I got a forged internal and my goal is 300-320WHP. I'm daily driver, So do I need this thing? Do anyone ran around 300WHP without it? or with it? Please share your experience and info.
Thanks
taoybb is offline
Old 01-30-2017, 03:51 PM
bbsciontc's Avatar
You definitely do not need a "block guard" or sleeves for that power level. Forged internals will be more than enough. Many have run 300whp even on stock internals, although I think that's kinda pushing the limits. Better spend that money on good tuning options, ideally, a standalone engine management system and proper fueling.
bbsciontc is offline
Old 01-30-2017, 05:24 PM
taoybb's Avatar
Thanks , Then I would leave block guard option. For tuning , I already have separate amount of budget of that part. Other part is I already upgraded fuel, cooling, suspension, engine management system, exhaust. This might be good to go right now.
Thanks again for your clear answer.
taoybb is offline
Old 02-22-2017, 07:46 PM
Paris's Avatar
No need for a block guard. they do more harm than good. also stock internals have been proven to hold 300+whp reliably
Paris is offline
Old 02-24-2017, 02:47 AM
taoybb's Avatar
Thanks .
What about oil. Should I remove balance shaft to get more oil pressure?
taoybb is offline
Old 02-27-2017, 05:26 PM
IFeelYourPain's Avatar
They can cause hotspots.
IFeelYourPain is offline
Old 02-27-2017, 06:42 PM
taoybb's Avatar
You mean block guard ?
taoybb is offline
Old 03-01-2017, 12:29 PM
bbsciontc's Avatar
Yes. The side effect of using them is that they impede coolant flow, and will in turn reduce cooling performance. This is probably not a good thing as the 2AZFE is already known to pull out the threads from the block that attach to the middle head bolts if it is allowed to overheat.
Old 03-01-2017, 02:11 PM
taoybb's Avatar
Oh thanks bbsciontc for detailed info.
taoybb is offline
