View Poll Results: Which would look better on an RS 2.0???
Stock Clear w/reflectors?
0%
Blacked Out w/reflectors?
100.00%
Voters: 12. You may not vote on this poll
Blacked out inside of xb taillights... Opinions...
Old Apr 22, 2005 | 04:24 AM
totallyboardz's Avatar
Strictly Scionized
Default Blacked out inside of xb taillights... Opinions...
I haven't gotten to mount these on my RS 2.0 yet, but I just blacked out the inside of the taillights. I had planned on just getting rid of the red reflectors, but once I had them apart it looked better keeping the reflectors and making the insides dark. The pics aren't the best, but what do you think. Keep the stock lights or go with the blacked out look. I've got both pair, so maybe I'll just switch em once in awhile.
Old Apr 22, 2005 | 04:52 AM
hotboxn's Avatar
Team Echo
depends on the color xB its going on.
Old Apr 22, 2005 | 05:04 AM
OrAnGeBoX's Avatar
Yellow
Old Apr 22, 2005 | 05:05 AM
Boxer_Rebellion's Avatar
Killer man! i'm doing the same thing, but just the top half. How does it look from the side (edge) view? Also, what did you use to do it? Any sealing problems?
Old Apr 22, 2005 | 05:14 AM
sensez's Avatar
the right tail (in the pic) looks darker.
sen-
Old Apr 22, 2005 | 05:21 AM
siclmn's Avatar
Why not just black out the whole light? Then someone won't just barely see your little brake light showing no they will just ram the hell out of your box and you will be dead.
Old Apr 22, 2005 | 05:28 AM
Umm, no. If you only do a few coats 80-90% of the light is still transmitted...
Old Apr 22, 2005 | 05:37 AM
crayonBOX's Avatar
get some really good led lights, then you're in business, btw, what was your process of blacking/smoking these tails... and are the two lights in the pic smoked to different levels?
Old Apr 22, 2005 | 05:50 AM
TJandBOXCARWILLIE's Avatar
I'm thinking that the stock brake lights aren't that bright in the first place, so why make them darker?
I dunno. Around where I drive, the brighter the better. I know I don't want some monkey smashing into my Box because they could not see the brake lights.
Old Apr 22, 2005 | 06:06 AM
Max2k's Avatar
These aren't smoked. The inside is painted and the lens is left clear.
The brake and turn signal lamps are not significantly darker. The bulbs are still exposed, and you can see the light fine. Trust me, I've been driving around with this setup for months and haven't had any problems.
LED bulbs are not, I repeat, not brighter than incandescent bulbs. They never will be. Your best bet is to stick with the ones Scion gave you.
There won't be any sealant issues, as the tail lights are sealed with a foam bead that isn't affected by repeated opening of the light. It's the headlight you want to worry about.
In any event, good looking out.
Old Apr 22, 2005 | 06:40 AM
crayonBOX's Avatar
hey max, i still dont get it.. is the 'reflector area' painted black?
and the only reason i suggest led, is because w/a reputable brand, ive noticed (only at night) better penetration thru the smoke film (bluebat type stuff) tho you're right, nothing is brighter than the incandescent included.
as for openeing the tail, im trying right now, but i cant seem to get the tabs to go back far enough...care to do a quick run down for me again?
thx
Old Apr 22, 2005 | 10:34 AM
Blue_Batmobile's Avatar
Looks great. Can't wait to see them on your car.
Bat™
Old Apr 22, 2005 | 12:27 PM
Hmm yeh I can't figure it out. The one's on the right look painted inside but the ones on the left look smoke tinted (it seems you can still see silver in the reflector...) or is that just lighting. What's up totallyboardz?
Old Apr 22, 2005 | 04:29 PM
Strictly Scionized
Okay... The one on the left is a stock taillight. I didn't even open it up yet. The one on the right I opened up and blacked out all of the silver. I used black vinyl instead of paint just in case I didn't like the look. But, now that the one is done, I think I'm going to stick with it.
I didn't touch the actual lens. It is still perfectly clear. I left both of the red reflectors in the housing to keep it legal. There really shouldn't be too much of a difference in visibility. Safety and legality were the reasons I did it this way. I wanted something different than the stock tails (my girlfriend said to leave em alone because she liked the stock look) but I didn't want to go with the altezza look lights or leave them clear.
As for removing the lens, I ended up using a dremel to shave a little off of the taps. Once I get everything the way I want it I'll just glue em tight. For forty buck for a set of taillights on eBay, I think this was a good deal.
Fedex just showed up. Yeahhh... My speaker box is here. You will all want to see this. I'll post pics of the lights when I get them on tonight. I have to get them in because the box is probably going to cover the access panels.
Old Apr 22, 2005 | 04:58 PM
Cool thanks for the info.
Old Apr 22, 2005 | 05:15 PM
bB_Local_Boy's Avatar
wait, check out this thread before you cut the tabs.
https://www.scionlife.com/forums/vie...il%2A+light%2A
Click the first guy's included link for pictures.
Old Apr 22, 2005 | 06:09 PM
Strictly Scionized
yeah, thats the thread I went by, but the lenses started to crack when I did it that way. Just taking a little off with a dremel let things slide apart easier and now that there back together, you can hardly tell.
Old Apr 22, 2005 | 08:31 PM
LavaBox_v1's Avatar
It looks good! I like it!
Old Apr 22, 2005 | 09:16 PM
Strictly Scionized
Got them mounted on the xB along with putting in my custom box this afternoon. I'll post pics ASAP (probably Sunday, got to work the next two days).
Old Apr 22, 2005 | 09:45 PM
Strictly Scionized
Now that I have the lights in, they are just as bright as before. I really can't tell much of a difference when I had the stock light on one side and the blacked out light on the other.
