Register Forgot Password?
Reply
Old 04-24-2005, 08:47 AM   #1
llgotscionll
llgotscionll 13/M
Send a message via AIM to llgotscionll
Default Tire Inflation Reset Button
I rotated my tires today and I noticed that my tire pressure light suddenly came on. I went to the gas station to put air into my tires and saw that the pressure lights were still on. So I decided to read the manual and it said that once I filled up the tires with air, I need to press the tire pressure reset button. Does anyone know where it is??
2005 Scion TC
llgotscionll is offline   Reply With Quote
Old 04-24-2005, 09:24 AM   #2
TurboMe
TurboMe 113/M
inside the glove box there should be a little button on the top left corner
TurboMe is offline   Reply With Quote
Old 04-24-2005, 03:50 PM   #3
boostedscion
boostedscion 32
lol... that's easy
boostedscion is offline   Reply With Quote
Old 04-24-2005, 04:23 PM   #4
llgotscionll
llgotscionll 13/M
thanks.
2005 Scion TC
Old 04-24-2005, 04:48 PM   #5
Lonely_Raven
Lonely_Raven's Avatar
Lonely_Raven
Send a message via ICQ to Lonely_Raven Send a message via AIM to Lonely_Raven Send a message via MSN to Lonely_Raven
Wow, I didn't know the tC was so diagnostic. That's pretty cool.
The Lonely Raven
Jack of all Trades,
Master of None
Lonely_Raven is offline   Reply With Quote
Old 04-25-2005, 06:00 AM   #6
llgotscionll
llgotscionll 13/M
I pressed the reset button inside the glove box and the light goes away. Then 15 minutes later, it comes back on. What is wrong with my tC??
2005 Scion TC
Old 04-25-2005, 06:03 AM   #7
hejustlaughs
hejustlaughs
Send a message via AIM to hejustlaughs
Kiss it first... j/k. Hmm That's weird. Your tire pressure sensor works off your abs... it should've calibrated itself. Did you drive around for 10 minutes and the light came back on or did you wait 10-15 minutes then the light just came back on?
rawr. baby. RAWR.
hejustlaughs is offline   Reply With Quote
Old 04-25-2005, 06:24 AM   #8
dsmith5237
dsmith5237
Quote:
You should check the tire pressure of all of your tires. If one side is different by more than a couple pounds it'll trigger the light.
dsmith5237 is offline   Reply With Quote
Old 04-25-2005, 07:25 AM   #9
llgotscionll
llgotscionll 13/M
Thats what I did. I was at the gas station and all the tires were around 39 psi. Maybe my friend rotated my tires wrong??
2005 Scion TC
Old 04-25-2005, 07:57 AM   #10
Boobala
Boobala
IF you have the standard 215/45ZR17 tires, you're setting the pressure too high, they should be inflated to...
Front - 32psi (31.9psi to be precise)
Rear - 29psi
1) Adjust tire pressure as indicated above.
2) Turn ignition switch ON. If the tire pressure light comes on, press the reset switch (in glovebox) and release it.
3) Press and hold the tire pressure reset switch until the low tire pressure warning light blinks three times.
4) (Re)Initialization is completed after driving on smooth, dry, straight roads at a speed of 19mph to 62mph for an hour. (Max two people in car, including driver)
Boobala is offline   Reply With Quote
Old 04-25-2005, 08:44 AM   #11
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
Send a message via AIM to DouBLeJ16
I rotated my tires yesterday and the light never even came on. kind of weird.
I don't understand how it works if nothing is actually connected to the rim or tire.
- K&N CAI, Megan Header & S-pipe, Megan Drift Spec Exhaust, AP Crank Pulley -
9.82 @ 73.44
^^ Traded in for '04 350z (8.87 @ 81.3mph bone stock down to the air filter & tires)
DouBLeJ16 is offline   Reply With Quote
Old 04-25-2005, 09:07 AM   #12
Boobala
Boobala
Each wheel (hub) has a speed sensor, and as the outer diameter of the tire changes with inflation pressure, the speed of the wheel changes in relation to the other wheels. The ECU measures the difference, and if one wheel is out of whack with the others, it throws a tire pressure warning light.
Old 04-25-2005, 05:21 PM   #13
llgotscionll
llgotscionll 13/M
Rear - 29psi
Aite thanks...I'll try adjusting the tire pressures.
2005 Scion TC
Old 04-26-2005, 08:28 AM   #14
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
what does the tire pressure light look like and where does it show up? I want to make sure it's that and not the CEL.
9.82 @ 73.44
Old 04-26-2005, 08:54 AM   #15
llgotscionll
llgotscionll 13/M
sorta like this ( ! )
2005 Scion TC
Old 04-26-2005, 09:00 AM   #16
DouBLeJ16
DouBLeJ16's Avatar
DouBLeJ16 30/M
oh, ok.. it's definately my CEL then
9.82 @ 73.44
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2010, air, blinking, button, correctly, inflated, inflation, light, low, pressure, reset, scion, switch, tc, tire, tires, xb, xd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
