What Amplifer should i get to power this sub?
Old May 14, 2005 | 04:23 PM
Greg2385's Avatar
Default What Amplifer should i get to power this sub?
I am thinking about buying the Elemental Designs 13ov2 sub woofer. I am not sure what amplifier to get to go with this subwoofer. Would you guys recommend this sub woofer? I'm going with ED because i dont want to waste trunk space with a large box.
Any feedback is appreciated.
Thanks in advance.
Greg
Old May 14, 2005 | 11:19 PM
scionspecialistvegas's Avatar
a big one with lots of power, J/k, GO with what your budget will allow.
Old May 15, 2005 | 01:29 AM
J_A_Trevino's Avatar
what is the rms for the sub? if its a sub that needs a good bit of power look into the hifonics amps youll get quite a bit of bang for your buck.
Old May 15, 2005 | 02:59 AM
Greg2385's Avatar
My price range is $200.
Here is my sub woofer info:
Power Handling : 600WRms
Sealed Box Size : .6-1.1cF
Vented Box Size : 1.2-1.5cF
Infinite Baffle Capable : Yes
Avaliable VC's - Dual 2 / 4
Qts : .28
Qms : 3.3
Vas : 176
Bl : 21.7 Xmax : 18.3mm
Weight : lb
SPL :
Mounting Depth : 6.75
Mounting Diameter : 11.00
Click Here For Dimensions
Co-Linear Enhanced : Yes
FLEX Suspension : Yes
Eu-Surround : Yes
Stamped (+) Basket : Yes
Vented Cooling System : Yes
Old May 15, 2005 | 02:25 PM
failed_ethics's Avatar
13Ov2 can take well over 600w, and love it. Great sub, good choice.
As far as amps, the nine series is out of your price range, and all i've ever run are those and avionixx so I can't help you any farther than that. But the avionixx's are great amps.
Old May 15, 2005 | 02:36 PM
chadfo's Avatar
If you haven't already bought the sub, go to their package deal page. 1 dual 2ohm 13Ov.2 and a Nine.2 amp is only $348.50 shipped. You may even be able to get a discount off that for being a Scionlife.com member.
The Nine.2 amp is rated for 400W X 1 @ 4 ohms and that should be plenty to move that sub.
I can attest that they sound great and man do they pound!
Old May 15, 2005 | 04:43 PM
LavaBox_v1's Avatar
Call ED and ask them what they suggest ... its their sub, they will know what amp will work best
Old May 15, 2005 | 05:23 PM
mike51392's Avatar
i have a sony gtx2200 its sick i think when brigged it puts out 800watts rms at 4oh i got mine for $169.99 from circuitcity.com then i picked it up at a near by store
Old May 15, 2005 | 07:33 PM
Greg2385's Avatar
Thanks for your replies. I will probably call ED but i'm sure there gonna reccomend / suggest one of their own amps (obviously). I'll look into the avionixx like failed ethics said.
I haven't bought the sub yet, so i can check out the package from the ed website.
Thanks fot the feedback. Any other suggestion would be appreciated.
Greg
Old May 16, 2005 | 12:34 PM
SCI_TC_GUY's Avatar
Hifonics does put out quite a bit of power for the price....
http://www.woofersetc.com/product.as...5&1=296&3=3576
That amp will throw the sub around rather well!!!
Old May 16, 2005 | 04:46 PM
i am actually going to try to get one or two of the brutus 15oo's or 1 2200d for my new system which is in the works.
Old May 16, 2005 | 06:14 PM
fivepointnine's Avatar
Elemental designs seem to be pretty cheap, does that reflect in build quality and longetivity or is is just one of those "too good to be true, but its really true" type things?
Old May 16, 2005 | 06:26 PM
you're pretty much buying direct, cutting out the middle man. Basically, you're getting the "dealer prices." They use to have a nice chart showing how much it would cost if you bought their products from a retailed, nice discount.
Old May 16, 2005 | 07:31 PM
mandos's Avatar
Well, if anything ever goes wrong, we have a 3 year warranty on everything
As failed just mentioned, we sell everything direct. No dealers=no extra markup. Plus most advertising is done through word of mouth or other things like sponsoring this section of ScionLife....a lot less expensive than running ads constantly in different magazines which in turn allows us to keep the costs down.
Regarding what I'd suggest for a 13Ov.2, since I'm the one answering the phones.......Nine.2 is an excellent solution with the dual 2 ohm 13Ov.2. If you ever wanted to upgrade, you could get a Nine.1 for a bit more power and better effieciency but a larger price tag.
The Dual 4 ohm 13Ov.2 is on backorder right now but could go with a Nine.1 if you wanted to get a ridiculous amount of power to it....plus running two of the D4's to a Nine.1 is just about perfect
Old May 16, 2005 | 08:12 PM
hmmm........thanks for the info guys, I think Ill look into ED next month when I do my full system.
Old May 16, 2005 | 09:23 PM
Greg2385's Avatar
Thanks for the info. I think i am going to go with the 13ov2 and the nine2 amp. It comes out to be just under $400 which is just in my price range. But i wont be ordering it untill after i install my intake.
gedster314
14
Nov 17, 2018 02:56 PM
ScionLife Editor
Jun 17, 2015 05:22 PM
ScionLife Editor
Feb 25, 2015 04:40 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
