turbos 200+ HP?
Old Feb 27, 2004 | 09:53 PM
xbracer's Avatar
Default turbos 200+ HP?
yo, they any turbo kits that push 200HP and will still make the engine last a reasonable amount of time?
Old Feb 27, 2004 | 09:54 PM
deathcabforme's Avatar
no
HotBox's Avatar
hate to say it but keep on dreaming buddie bear
Old Feb 27, 2004 | 10:13 PM
TeamMightyMiniz's Avatar
I beleive a straight outta the box turbo kit will give you at the most, and extra 30-50 hp
Old Feb 28, 2004 | 04:01 AM
looks like your going to have to do an enginew swap if you want 200+ HP . Or maybe get the scion tC.
Old Feb 28, 2004 | 06:48 PM
jackmott's Avatar
some low compression forged pistons and you could probably do it.
but then the low rpm power would be significantly worse than it already is. wouldn't be fun to drive.
Old Feb 28, 2004 | 06:55 PM
ScionBandit's Avatar
DelMarVa
Scion Tuners
ye buddy, ur kinda short on that one.....swap it!!! its good for u
ne one considered tC motor in the xB?? i know its hte 2.4l 4cyl. camry engine, ne problems fitting it in?? w/supercharger??
just a thought
_________________
Lamborghini Gallardo
Old Feb 29, 2004 | 11:17 PM
TC in an xB.... Would that make it an xTC?
I doubt it will work, but you never know... run the numbers.
Old Mar 2, 2004 | 06:50 PM
Burn0ut's Avatar
it would take a lot of work and money (i.e. forged pistions, rods, valve springs, head gasket, rings, etc.) but if you got the compression low enough you could crank up the boost and maybe with some nitrious you could get it to 200 to the wheels.....but at that point good luck getting the power to the ground. :D
Old Mar 2, 2004 | 07:29 PM
qualityscion's Avatar
Or xTB(xtra Totally Blown)
Old Mar 3, 2004 | 03:37 AM
Sevedd's Avatar
Exactly what he said...
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
edwinisdumb15
Regional - Pacific South
Sep 18, 2015 10:48 PM
