for cheap people only
Old May 28, 2005 | 02:21 AM
fredrick_brown's Avatar
Default for cheap people only
Make your box quiet. Pull your back panels off where the speakers are located and the rear wiper panel just to the inside of the tag. Stuff it with foam or expand a foam in the can. It will get rid of panel flexing and vibrating tags from powerful subs. Also make exaust note lower inside the box your girl will love you for this.
Old May 28, 2005 | 02:25 AM
failed_ethics's Avatar
you know what you should use? ...punctuation.
just messing, foam is great for vibration dampening. I recommend carpet padding.
Old May 28, 2005 | 02:27 AM
aireck's Avatar
what did he say ???
ok slow down and try again...lol
Old May 28, 2005 | 08:28 AM
Better!This is not class guyz so lay off.
Old May 28, 2005 | 09:36 AM
xBino's Avatar
hey fredrick
how'd you get the back panels off? the 2 bolts on each side are encased by this weird, plastic, hook thing and i don't know what size allen wrench i need
what else needs to be removed to access the side panels?
Old May 28, 2005 | 11:41 AM
Newtmaker's Avatar
10mm
Old May 28, 2005 | 12:04 PM
an 8mm allen.
Old May 28, 2005 | 01:59 PM
Newtmaker's Avatar
Right. 10mm is too big!!
Old May 28, 2005 | 10:55 PM
Sciond's Avatar
Originally Posted by hotbox05
an 8mm allen.
yes and it is easier to remove and do what you want if you take the seat out
Old May 29, 2005 | 01:25 AM
griecos_xb's Avatar
i just stuffed mine with old clothes that i don't wear anymore,works great
Old May 29, 2005 | 01:33 AM
xBino's Avatar
truly in the spirit of "on the cheap"
Old May 29, 2005 | 02:42 AM
firesquare's Avatar
Redneck Tuining! gotta love it.
-Paul
Old May 29, 2005 | 03:05 AM
morningman's Avatar
-Paul
Dont diss on rednecks man
Old May 29, 2005 | 03:44 AM
uber-xA-RS2's Avatar
Sheets of polyester batting (commonly used in upholstry and bed covers) comes on rolls that you can cut and fit to any space or size you need. It's available in different densities and it's pretty cheap.
Works really well too since its a very dense material.
Old May 30, 2005 | 09:04 AM
xBino's Avatar
hear's a good but long read on sound deadening on the cheap
https://www.scionlife.com/forums/viewtopic.php?t=60459
Old May 30, 2005 | 03:23 PM
TheIcon's Avatar
Ok so I read it basically and I have thought about using Pink Panther insulation on my car. But he brought up the fact that it coudl get moldy etc if water gets to it.
Is this safe to use on the insides of our door. Like stuffing our door? Or should we just use it on the inside of the door where the door panel is?
I was going to use it wher ethe door panel was and stuff some on the inside of the door as well (but out of the way of the window so it can wind down)
Old May 30, 2005 | 04:23 PM
chadfo's Avatar
Water gets down in the door panel. If you are worried about mold in the insulation, do not put it in the panel. Keep it between the blue vapor barrier and the interior door panel.
Old May 30, 2005 | 04:55 PM
firesquare's Avatar
-Paul
cant diss anymore, im a North Carolinian and LOVE it
-Paul
Old May 30, 2005 | 10:34 PM
i cut the foam out of a civic seat and stuffed the bottom.at the top in the tight spaces used expand a foam.but just start with the lift gate first then see how it sounds.
Old May 30, 2005 | 11:54 PM
Newtmaker's Avatar
Timely post. I just put new rear speakers in my xb. I had just read these posts while taking a break. Had my wife p/u some polyester fil batting at the craft store. I stuffed it in the rear side panels and in the rear hatch. It actually does make a noticable difference! Had my daughter drive me around while I sat in the back seat and listened. Damn!! I sure love this xb!!!
Walt
