Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Suspension & Handling
Register Forgot Password?
Reply
Old 06-08-2005, 06:27 PM   #1
rolfsy
rolfsy
Default Best first step to improve general road manners.
Hello all,
New to the xA (two days old, 50 miles). Drove a '93 Paseo for about 10 years, so I'm really used to the unflippable go-cart handling from the low and light 'Super Tercel'. Now with the 'Super Echo', and most other modern econoboxes I looked at, the ride is far closer to SUV than I'm comfortable with. (1.26 static stability rating is actually under standard passenger car threshold of 1.30) . The wake-up call was coming home from the dealer on the e-way and deciding to exit at the last minute. Waaaay more squeeling and pitching than expected as I darted over to the ramp. Reminded me of the old family Oldsmobile with 100,000 miles on it.
So anyways, after all that background crud, would appreciate input on the best single way to improve handling for general driving. Not a tuner, not going to the track . . . I really like this car except it actually feels a bit unsafe when you throw its weight around. Just wondering if the strut or sway bar add-ons are worth the money for normal, sometimes-spirited, driving.
Thanks,
Mike
rolfsy is offline   Reply With Quote
Old 06-08-2005, 06:45 PM   #2
latinotke639
latinotke639 30/M
depends on how much money u wanna spend, easiest way, just drop in some new springs, and the strut bar will help
"and when I leave, it come together like butt-cheeks!"
latinotke639 is offline   Reply With Quote
Old 06-08-2005, 06:59 PM   #3
Janus
Janus
Lowering the car is the most important because if you're too high up it doesn't matter what other mods you do
Janus is offline   Reply With Quote
Old 06-08-2005, 07:36 PM   #4
xBino
xBino's Avatar
xBino 113/M
to improve overall handling for not a lot of dough try this (in order):
Cornering Improvement:
1) lowering springs ~$130 (very noticeable)
2) rear anti-sway bar ~$130 (noticeable)
3) strut tower brace ~$80 (subtle... maybe it's in my head)
did a lot for my ride more than i think an intake or header would've done in terms of daily street driving. no sense going faster unless you can take the turns!
2005 xB RS 2.0 #122 - 5spd
xBino is offline   Reply With Quote
Old 06-08-2005, 08:00 PM   #5
rolfsy
rolfsy
Default Warranty?
Thanks a bunch for the replies. Sounds like lowering is the way to go.
Does this do anything crazy to ground clearance? I wouldn't imagine so - seems like the xA is oversprung to begin with just looking at the wheelwells.
More importantly, if you DIY does it cancel out any warranties?
Mike
Old 06-08-2005, 08:06 PM   #6
TheScionicMan
TheScionicMan's Avatar
TheScionicMan 113/M
Special sauce gave the list i would've given, but i would've singled out the Progress bar for the rear.
If you DIY, you will negate the warranty on the OEM springs since they will be sitting on your shelf or something. Otherwise, it has to be proven that the aftermarket part caused the failure for it not to be warrantied. And I've yet to hear of a spring -related failure on here...
www.TheScionicMan.com
http://www.digitalradiocentral.com
TheScionicMan is offline   Reply With Quote
Old 06-08-2005, 08:29 PM   #7
xBino
xBino's Avatar
xBino 113/M
you can do it man! i have faith in you! just don't screw up!!! j/k
seriously, these things are hard to install incorrectly given the tech resources/articles, the right tools, and a little paitence. just take your time and let us know if you hit any roadblocks
Old 06-11-2005, 04:27 PM   #8
DEATH666
DEATH666 113/M
Default handling
one word; Hothckiss. I went with the springs, sway bars and strut tower barce. It all works together. The quality , price and performance are all quite good. Just my opinion.
black sand pearl XB, hotchkiss sway bars,springs,strut brace.18" wheels,leather interior,CAI,header and exhaust, interior/exterior lighting,Blitz Supercharger,perrin pulley
DEATH666 is offline   Reply With Quote
Old 06-14-2005, 12:26 AM   #9
TXboxdriver
TXboxdriver's Avatar
TXboxdriver 35/M
Send a message via AIM to TXboxdriver Send a message via MSN to TXboxdriver Send a message via Yahoo to TXboxdriver
stay off the phone while driving
that'll improve those "Road Manners"
TXboxdriver is offline   Reply With Quote
Old 06-14-2005, 09:39 PM   #10
SciFly
SciFly's Avatar
SciFly 59/M
195/50/15 GoodYear F1's were put on my xB a week ago.
These drop the car one half inch (more wheelwell gap, unfortuantely)
But they are fantastically great-gripping tires and -silent- in the most extreme cornering (unlike the stock Eagle LS M+S touring tires.
This under-400 "mod" gives you better cornering and better traction and better braking and better acceleration.
The last two improvements come via the shorter radius (hub to ground) which means that the final drive ratio is reduced AND also, the brakes' torque is increased.
Yes, this 50 series tire introduces speedo/odo error but by gum, they stick like gum.
IF you can "like" the small wheel look, this is a viable way to go. I love my new tire size. These are "Summer tires". Other summer tires with AA traction rating and lower than stock sidewall height should give similar results.
My F1 may say "goodyear" on the sidewall, but they were made in Germany/autobahnland
cheers,
Reid
SciFly is offline   Reply With Quote
Old 03-16-2007, 11:03 PM   #11
LeroyJMC
LeroyJMC 33/M
Send a message via AIM to LeroyJMC Send a message via MSN to LeroyJMC Send a message via Yahoo to LeroyJMC
I would personally recommend that you go with the rear sway and lower profile tires. You can add the rear sway in fifteen minutes. The tires....well you'd want some 17 or 18 inch wheels (18 inch with a 35 series tire will give you the best handling) with lower profile tires. Yeah tires and wheels are the most expensive, but they will make the xA look tons better. Test that set up for a week or two and see how you like it. Those are the two things that I noticed the biggest difference with. Then with those low profile tires, you'd be looking a little like you had a lift on the vehicle so you'd want some lowering springs.
So here's the order that I'd recommend.
1. Rear sway add-on (Progress in my case)
2. Low pro tires with some nice wheels (215-35-18's for me)
3. Lowering Springs (Hotchkis ~1.5 inch drop for me<this is about the same drop as the TRD springs and is an excellent choice for good handling yet not so low that you drag on everything>)
4. Upper strut tower bar (DC Sports Carbon Steel for me)
I may get slammed on the tower bar because some contend that it doesn't make much of a difference, but I installed mine before the rear sway and I could most certainly feel a quicker responce.
2006 Flint Mica XA
35% tint
18 x 7.5 Konig Unknown
215/35/18 Toyo FZ4
Eclipse AVN6600 with TV Tuner
DC Sports Carbon Steel Strut Bar
Progress Rear Sway
MMW 4-2-1 Header
AEM CAI with Bypass
RS-R Exmag GTII Exhaust
LeroyJMC is offline   Reply With Quote
Old 03-16-2007, 11:18 PM   #12
jct
jct's Avatar
jct 73/M
lower frame braces front and rear!!!
i replaced my airbags with confetti
ಠ_ರೃ
jct is offline   Reply With Quote
Old 03-17-2007, 12:36 AM   #13
LeroyJMC
LeroyJMC 33/M
I've been considering those duck_dodgers. How big of a difference can you feel? Do you do street driving only or do you autocross?
2006 Flint Mica XA
35% tint
215/35/18 Toyo FZ4
Progress Rear Sway
MMW 4-2-1 Header
AEM CAI with Bypass
Old 03-17-2007, 01:32 AM   #14
Jhhnn
Jhhnn 64/M
Either the Progress or TRD rear sway bar, first and foremost. Radically reduces body roll and understeer... Easy install. The best $150 you can possibly invest in handling, imho.
After that, grippier tires, maybe on larger rims. I personally wouldn't go larger than 17" rims and, say, 205/50R17 tires, so you'll have some sidewall left for potholes and ride characteristics... lots of info here on what width and offset are good... also tire brands and models.. I've been eyeing a set of 195/60R15 Falken Ziex 512's...
If that's not good enough, then go to lowering... front strut bars and underbraces provide only small incremental improvements after that, if at all...
My front strut bar didn't seem to change much other than to lighten my wallet ...
Jhhnn is offline   Reply With Quote
Old 03-17-2007, 04:24 AM   #15
DriverXa
DriverXa's Avatar
DriverXa 26/M
I'd say the first thing you should do is get the TRD swaybar. The xA does not come with one at all and this should be on the top of your list followed by better tires, strut bar, then springs and struts. There shouldn't be any problem with warranties as they are not allowed to void it unless they can prove the modification u did caused the problem but then again most dealers use any excuse to get out of warranty work as they obvioiusly lose money. If ur really paranoid about the warranty than buy the TRD parts online for cheap and install them urself, then there should be no excuse not to warrant the car as its they're cr@p(if they pull the "but u still installed it" bs they still can't deny warranty bcuz TRD parts are 1. made for the car 2. are warrantied by themselves for 12 months if u do it urself or if u have them install it fall under ur bumper2bumper warranty. If u go this route remember they're parts they're problem)
www.teamscionrg.com
DriverXa is offline   Reply With Quote
Old 03-17-2007, 04:40 AM   #16
joshsbox
joshsbox's Avatar
joshsbox 34/M
I don't know if anyone mentioned, but change out your front swaybar bushings for polyurethane...it does make a difference.
Life is a journey, enjoy the ride...
joshsbox is offline   Reply With Quote
Old 03-17-2007, 04:50 AM   #17
jct
jct's Avatar
jct 73/M
Quote:
street driving only
ಠ_ರೃ
Old 03-17-2007, 08:16 AM   #18
bB2NER
Music City Scions
bB2NER's Avatar
bB2NER 109/M
Send a message via Yahoo to bB2NER
In order of importance...
1. rear bar. (TRD,Progress or Whiteline)
2. Lowering springs
3. front strut bar.
4. front bar bushings ( Energy)
5. low pro tires
and Monroe rear shocks for ride comfort.
Jeff
05' BCP xB W/ 48K miles
08' Absolute Red Yaris LB 5spd. W/ 42K miles
bB2NER is offline   Reply With Quote
Old 03-21-2007, 05:21 PM   #19
stangdude22
stangdude22 27/M
One this to keep in mind about big rims and low pro tires is that they do decress sidewall "give", but it also increases unsprung wieght, and incresses the rotational mass/wieght of the wheel. so turning will improve but breaking and accell will decrease slightly, but noticable
2006.5 xB
Eibach pro-kit, monroe shocks(rear), progress sway bar,
Fugita CAI, Magnaflow muffler, TRD shifter
Konig Feather w/ Nitto NeoGen 205/50/16
stangdude22 is offline   Reply With Quote
Old 03-21-2007, 05:50 PM   #20
Batmobox
Batmobox 33/M
I have the front strut bar and I love it. It makes turning a blast.
Batmobox is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
handleing, improve, step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
