need component speaker help
Old Jun 10, 2005 | 05:52 PM
yellot00tr's Avatar
Default need component speaker help
ok-i need to get new speakers for my tc. i've heard that you can go 6.5 in both the back and front. i'm trying to figure out what to get-i wanna spend arround $150-$175. if possible, i don't wanna have to buy an amp to amp the components, but if i have to-i guess i'll do it. does anyone have a setup they really like? i was looking at the elemental designs components or the alpine spr17-ls. does anyone have a suggestion between either one of those or something close to that in price?
Old Jun 10, 2005 | 05:55 PM
SCI_TC_GUY's Avatar
the EDi's will blow alot of other speakers out of the water!!!! I'm not sure if the 6000s needs to be amped or not....I would think so.....
Old Jun 10, 2005 | 06:03 PM
EazyM3's Avatar
you can't run components without an amp or you will probably damage your components by underpowering them, so you will definitely need an amp. also, you will get better staging if you only run components up front and remove your speakers in the rear. MOST, if not ALL, competition audiophiles run no "rearfill" in the back. the idea is that you're supposed to hear sound in front of you, NOT behind you... but do what you prefer.
rather than spending $150 to $175 on components front and rear, i would rather combine the money to buy 1 really nice set for the fronts. in order to recommend something, you should first tell us what types of music you like to listen to? i can't comment on the eD components, but their amps and subs are decent, especially for the money.
Old Jun 10, 2005 | 06:25 PM
dgHotLava's Avatar
no ofense, thats the wackest thing i ever heard....
you can not under power....
Old Jun 10, 2005 | 06:28 PM
yellot00tr's Avatar
mostly house and trance. some hip hop. i have a 6.5 memphis prcs highs already, they're just not installed. that's why i want to get another full set with tweets and x-overs.
tChris's Avatar
Actually you can thats how my friend fried his subs.
Old Jun 10, 2005 | 06:34 PM
dgHotLava's Avatar
impossible.
i work in the industry (18yrs experience). it can not blow from under power.
under power just means less output potential.
who ever told your friend this just wanted him to spend more money...
no such thing as under powering...that would mean if you listened with the volume low your speakers would blow...just plain dumb logic....
Old Jun 10, 2005 | 06:39 PM
Dr_Isotope's Avatar
People can indeed blow speakers by underpowering them... but underpowering isn't actually the cause of death. The final cause is the user turns the gains all the way up, and cranks the volume until they're hitting 20% THD, then the subs just tear themselves apart.
Distortion kills speakers... the human ear is virtually deaf to low-freq distortion... people do stupid things.
So underpower can be dangerous to speakers-- in certain people's hands.
Old Jun 10, 2005 | 06:57 PM
violent_b's Avatar
I think he means underpowered being overdriven. if you don't have enough power to run your speakers at the volume you want (most likely loud), you distort the speakers, and distortion is what damages speakers. the smaller the speaker the less chance you can hear the distortion until it's too late.
Old Jun 10, 2005 | 07:00 PM
SCI_TC_GUY's Avatar
there are alot of low-end components that only require 20-50 RMS watts that don't REQUIRE an amp.....it may be better by using an amp....but you don't HAVE to have one......EDi's i think you absolutely DO need an amp because you'll never get the needed RMS from the HU (even aftermarket).....
dgHotLava's Avatar
this makes better sense...
underpower on its own will not do damage...but clipping or distortion will wreck havoc...
Old Jun 10, 2005 | 07:02 PM
madhouse247's Avatar
If you don't plan on using an amplifier for the components you might as well leave the factroy speakers in. you might gain a little in clarity but you will have less volume and run the risk of sending a distorted signal and blowing something. Buy a one good set for the front and get a 4-channel amp to power the whole system.
Old Jun 10, 2005 | 07:11 PM
toastbox's Avatar
impossible.
How do you figure you can't underpower speakers????
Underpowering the speakers means that the voice coil isnt getting the proper excursion (movement in and out of the magnet t). This causes excess heat on the voice coil, which in turn causes clipping. Excess heat will cause the voice coil to burn out.
Are you suggesting that isnt true??
Old Jun 10, 2005 | 07:43 PM
dgHotLava's Avatar
impossible.
you are so close but still far off....
clipping, is created when the amp is not able to supply the power demand when the volume is turned up. If you turn the volume up very high without the power to back it up, you'll end up clipping the signal coming out of the amp. The speaker will try to reproduce this clipped signal, and if played under these circumstances for any length of time, the speaker will not last very long.
Old Jun 10, 2005 | 08:06 PM
toastbox's Avatar
ummmm, how exactly is this:
If you turn the volume up very high without the power to back it up...
*not* underpowering it??
Sorry, hit the submit button a little to quick...
I guess technically, as long as you don't turn the volume out so loud that the signal distorts, there wouldn't be any harm (as there would be no clipping). However, if you bought a set of components that were designed for ~ 75+ watts RMS (example, mb quarts Q's, or DLS iridiums) and you were only supplying ~25 watts RMS ( rough guess of what the stock HU is capable of), how loud do you think you are going to turn the volume up before the signal distorts?
Old Jun 10, 2005 | 08:10 PM
dgHotLava's Avatar
finish the sentance... you'll end up clipping the signal coming out of the amp.
the signal quality it the problem when underpowering.
not the lack of power....
figures you'd still miss the point.
Old Jun 10, 2005 | 08:29 PM
toastbox's Avatar
Maybe I'm taking this the wrong way, but for a super mod, you either don't seem to be following the rules (no personal attacks in your posts).
Lol, what you are saying:
a person has a car stereo, connected to a cheap amp, connected to set off speakers.
person turns the car stereo up, the amp is unable to create enough power to replicate the signals correctly, and clips the sound (square waves), the amp then sends the clipped signal, amplified, to the speakers. The speakers then melt the voice coil.
So in essence, what you are saying is:
the fact that the signal is clipped is what causes the speaker's voice coils to damage, *not* the lack of power. Correct?
Old Jun 10, 2005 | 08:38 PM
Dr_Isotope's Avatar
Precisely. It is the lack of power misused that is dangerous. The exact same way people blow out stock speakers on stock HU power, when the OEM drivers are at least 15w RMS, and an OEM head generally produces 4-7 watts...
Old Jun 10, 2005 | 08:50 PM
dgHotLava's Avatar
now you are thinking....(no attack...lol)
distortion and clipping at any power level are what causes the damage...
so, underpowering on its own is not bad for speakers.
now do we dare go into RMS and peak issues?????
12v ratings or 14.4v ratings????
Staging, resonance...
Old Jun 10, 2005 | 08:52 PM
mandos's Avatar
eDi's will sound fine off the stocker in a tC. Did it myself for a day since I promised my parents I wouldn't drive it w/o an interior...and I need sound.
Yes, they'll sound infinitely better when amped, but they'll do fine w/o an amp as long as you don't crank the deck to it's limits. It's a decent deck, but it will still clip.
Oh...and with the whole distortion vs. underpowering.
People without the available power want to get louder...so they turn it up to the point where the wave form becomes square. Meaning that the speaker is supposed to instantaneously move from peak to peak, there is no in between. This = heat = burnt coils and not a warranty issue for any manufacturer.
More power, keeps a sine wave = the speaker is supposed to travel linearly and will disappate heat properly
