Larger tires on stock wheels?
Old Mar 8, 2004 | 07:24 AM
Torokun's Avatar
Default Larger tires on stock wheels?
Has anyone tried mounting larger tires on the stock wheels?
If you have, what size did you go for?
Old Mar 10, 2004 | 05:06 PM
Torokun's Avatar
No one has done this yet?
:cry:
Well, if anyone tried mounting wider tire on the stock rim... Please let me know how it turned out...
Old Mar 11, 2004 | 07:26 AM
Minsk99's Avatar
I'm not putting larger tires on stock, but am going to put beefy tries on 15"x"8. I'll post pictures in a week or two when complete.
Old Mar 11, 2004 | 07:37 AM
Al-Truistic's Avatar
I am thinking I will after the stock rubbers need to get changed...
Old Mar 11, 2004 | 07:53 PM
Torokun's Avatar
i'm sorry... i didn't mean "larger" but, "wider" tire...
Old Mar 11, 2004 | 10:06 PM
George's Avatar
Default Re: Larger tires on stock wheels?
I'd like to, to get the cruise RPM down a bit and pick up a bit of ground clearance. I figure I can get away with about two inches in diameter.
Using the tirerack calculator I get:
stock: 23.7 in diameter.
A 205/65R15 tire will have an OD of 25.5, 1.8 inches more than stock. This tire would reduce the engine RPM by 7.5%, taking the 3000RPM at 60MPH down to 2775RPM. It would also have a bit more sidewall bulge, protecting the rims and hubcaps better than the stock tires.
George
Old Mar 11, 2004 | 10:23 PM
Does that make it more dangerous in bad weather (ie:hydroplaning?) I like the idea of protecting the rims!
eric_m
52
Jan 17, 2019 05:50 AM
scionlife
371
Jun 2, 2015 11:00 PM
pscionicpowers
22
May 18, 2006 01:40 PM
avus
Oct 4, 2003 05:26 AM
