Perrin or Unorthodox
Old Jun 30, 2005 | 05:19 AM
KangaRod's Avatar
Default Perrin or Unorthodox
I'm not sure if you guys know or not, but Unorthodox racing is supose to be comming out with a pully set for our cars in the next month or so. What do you guys think of them as a company when compared to Perrin (the other underdrive available)?
Old Jun 30, 2005 | 07:14 AM
xmetalx's Avatar
well, they dont make under drives for our cars yet, just light weight pullys, so if the pully is lighter than the perrin one it might be a good buy
Old Jun 30, 2005 | 09:37 AM
unorthodox has been making them longer than perrin and they are good. very expensive but good.
Old Jun 30, 2005 | 11:00 PM
KangaRod's Avatar
does anyone know where are Perrin pullies made?
Old Jul 1, 2005 | 02:10 AM
Xbilly's Avatar
where did you get the info from, is unorthodox making a SET of underdrive pulleys or a lightened crank pully like perrin.
on a side note what is the concensus on the "harmonic balance" issue is the perrin really safe to use?
Old Jul 1, 2005 | 07:06 AM
KangaRod's Avatar
I spoke to Unorthodox directly. I am not terribly concerned with the harmonics issue because it is cheap enough to replace the 1NZ in the future (if it becomes an issue).
I never clarified, if they were just lightened, or underdrive. I know Unorthodox shies away from underdrive usually - so I would assume they are only lightened.
Is it worth the money for the pully though. I know I have seen quite a few with the Perrin at least.
Old Jul 1, 2005 | 10:34 AM
people like it. it's a good mod.
as far as harmonics? the stock pulley would be a crappy harmonic balancer. besides motors nowadays are blueprinted. and pretty balanced out the box. or in the box shall i say. lol
Old Jul 1, 2005 | 01:33 PM
Simplyscion's Avatar
Team No Limitz
I have been running my pulley for a few months and its fine...no extra vibrations, no noises from off balancing. I would definitely reccomend the perrin pulley if you are lookin to get a few more HP.
Old Jul 1, 2005 | 06:19 PM
KangaRod's Avatar
its a cheap enough mod too. Maybe I'll give it a shot
Old Jul 1, 2005 | 06:25 PM
Xbilly's Avatar
Im thinking I will too.
Old Jul 1, 2005 | 06:37 PM
Chimmy3's Avatar
the only real differences between the perrin and stock pulley design is:
the weight
the spokes
and the timing marker
So unless the harmonic balancing issue has to deal with weight .. there should be no problems
Old Jul 1, 2005 | 09:04 PM
eggie's Avatar
Aren't these motors internally balanced? Someone in another thread posted they spoke directly with a dealers service department and Perrin and the concensus was the motors are internally balanced.
Old Jul 1, 2005 | 11:11 PM
Rocket's Avatar
Unorthodox make very high quility products.
Old Jul 1, 2005 | 11:44 PM
eggie. they ARE blueprinted motors . aka internally balanced.
Old Jul 1, 2005 | 11:51 PM
CF_KC_WIDETC's Avatar
perrin#1
Old Jul 6, 2005 | 04:14 AM
87na's Avatar
Unorthodox does make good stuff but it is usually very expensive. I have some stuff from NST, www.NonStopTuning.com and I have really enjoyed the resutls. NST has a new pulley for the tC and there are some rumors that xA and xB stuff may be coming as well.
As far as pulleys go, here is some basic info. There are two benefits that can be had from an aftermarket pulley....
1. More HP. This is a result of Underdriving. Less power is sent to the accessories and more is left to drive the wheels.
2. Better throttle responce. This is a result of less rotational mass. You build the pulley using light weight aluminum instead of the heavy steel that Toyota uses.
To get more horespower AND better throttle responce you have to get a pulley that does BOTH.
Old Jul 6, 2005 | 05:14 AM
KangaRod's Avatar
Wouldn't lightening the recopricating assembly improve horsepower aswell as increasing throttle responce?
Perrin does state clearly:
Originally Posted by Perrin
The PERRIN Performance™ lightened crank pulley for the Scion xA & xB is engineered to reduce rotating mass, increasing horsepower and torque.
The PERRIN Performance™ pulley achieves power and performance by reducing the rotating mass of the crank assembly.
Everything I've always read puts a huge emphasis on lightening the recopricating assembly for increased horsepower. Underdriving would help, but obviously they felt the gains wern't worth the added stress on your engine accessories.
I ordered my Perrin pully today BTW. Should be in next week. I'll let you know how it goes.
Old Jul 6, 2005 | 05:48 AM
slipknot490's Avatar
hmmm
Old Jul 6, 2005 | 08:57 AM
well every blueprinted motor i've come across was internally balanced. maybe just on newer jap motors and semi newer not ancient euro motors.
Old Jul 8, 2005 | 02:35 AM
sarcasmkillsme's Avatar
I just checked on http://www.unorthodoxracing.com/ and it seems they have a pulley ready for our lil engines. Its an 'ultra S' underdrive pulley.
Crank Pulleys (Ultra S)
Code: 021212002
Price: $159.58
I'm interested!
