Last Minute Rim Question!
Old Mar 13, 2004 | 06:21 AM
Minsk99's Avatar
Default Last Minute Rim Question!
I ordered my 15 x 8 rims with an offset of 18. However, the rims also come in a 28 offset. I think that I can still change the order if I call tomorrow (3/13). I am going for the low and wide look, but will 18 offset stick out too much (as in problems when I hit a bump with a 2" drop)? This also might not give me an ability to have a lower offset in the rear. BTW I will be running 205/55/15 or 205/60/15 tires. Any thought would be much appreciated. Thanks.
Old Mar 13, 2004 | 08:14 AM
scionxb04's Avatar
hmmm....u might wanna get 28 its not that much different though....10mm is very little
Old Mar 13, 2004 | 08:28 AM
bBted's Avatar
10mm is not that much difference???
its huge!!!!
get 18
Old Mar 13, 2004 | 08:40 AM
Besk_one's Avatar
you should get 28 for the front, and 18 for the rear - 18 will mos def stick out in the front, but in the back it'll be niiiice!
remember there is a full 1" difference between the front and back - so stagger your offset for the most even stance
- my mod7's are 7.5" 42 front 35 back and the back is still sunk in more then the front!
- Brian
Old Mar 13, 2004 | 06:11 PM
Minsk99's Avatar
Thanks Besk. I'm gonna try and change the order to a stagged offset. I hope I can get the guy before the order goes out!
Old Mar 13, 2004 | 08:29 PM
scionxb04's Avatar
its huge!!!!
get 18
my 10mm spacers arent that thick i wouldnt consider that huge....its just over 3/8's....i had to put 15mm spacers in the back to get the rear to stick out somewhat close to front....
but Besk one has the best idea so far 28 front 18 rear
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
akwdcaveman
Scion tC 2G Wheel & Tire
Jan 17, 2015 12:47 PM
