DC strut bar install w/photos
Old Mar 17, 2004 | 02:52 PM
sithscripter's Avatar
Default DC strut bar install w/photos
DC strut bar install done the long way:
http://www.scionreview.com/modules.p...bnails&album=8
I'm a conservative driver but I've noticed a "tighter" and more precise feel when cornering. The sort of change that leaves one wondering what springs could do (nooooo, here I go again). I also noticed what seems to be an increase in vibration coming through the steering column -- nothing major though.
Old Mar 17, 2004 | 03:09 PM
Al-Truistic's Avatar
Thanks and the commentary was not only helpful but, entertaining as well! Nice strut bar! :D
Would you know if it is heavier than or the same as RandodeRacing's strut bar?
Old Mar 17, 2004 | 03:18 PM
scionracerxb's Avatar
do you reaally have to do all that? or is that just an "easier way" to get to that back nut. I'm willing to bet that it probably takes about the same time either way. that back nut is a b***h to get to :?
Old Mar 17, 2004 | 03:23 PM
abbfanuc's Avatar
i also did it the same way. But i think that if you had a hydrolic jack it would be faster doing it that way. By taking off the windsheild wiper assembly it is a b***h since one or two bolts is being blocked by the assemble.
Old Mar 17, 2004 | 03:38 PM
Jester's Avatar
How long did it take you to do? Using a jack took less than 30 minutes.
Old Mar 17, 2004 | 03:40 PM
DJ_X_Trodinaire's Avatar
mine is on the way!
thanks for the info
Old Mar 17, 2004 | 03:51 PM
Thanks for the kind words!
I'm pretty sure it's heavier than the Randode Racing strut bar. (The Randode is stainless steel, which is waaaaaaaayyyy more expensive than plain carbon steel.) But both are quite solid.
Old Mar 17, 2004 | 03:56 PM
The instructions actually recommend jacking the front end up while loosening that back nut. Eventually the studs will drop down just enough to get the nut on and off. But (a) I wanted to do something different and (b) I needed an excuse to disassemble something.
I'm guessing that this way takes slightly longer than the jack method. Total time: about an hour, much of it spent taking photos and looking for a 3" extension.
Old Mar 17, 2004 | 04:43 PM
Munch's Avatar
I have the same bar and love it. It's strong as hell. I stood on the damn thing after I installed it on my car and it wouldn't flex no matter how hard I jumped on it :D
Old Mar 17, 2004 | 05:15 PM
ricerocketdave's Avatar
that looks great, but do they make it in tiatainum????
Old Mar 17, 2004 | 05:17 PM
Munch's Avatar
This is the only color they come in.
Old Mar 17, 2004 | 05:59 PM
randode's Avatar
Wagonistas
i saw that on your car last sunday. Its really a nice piece. If you use a floor jack, the installation time is about 5 minutes ;)
Old Mar 18, 2004 | 12:44 AM
Five minutes?!?!?!?
Why would you do it the easy way and deny yourself all that fun?
Old Mar 19, 2004 | 11:29 PM
PIMP's Avatar
StyleWagons
I did mine today with a jack and took maybe ten minutes. After I loosened all the bolts, I jacked up one side until the wheel was maybe 4 or 5 inches from the pavement and then pressed down with my knee on top of the tire just enough to make the strut go down and slip the bar over the bolts. Started the bolts, lowered the jack, repeated other side and tightened all bolts. I couldn't center the hyd. jack because the car is lowered and I couldn't get the jack underneath far enough. You could use your car jack and do this meathod, it was easy just don't press down too hard and get your strut bolts misaligned, it may be hard to get back into the holes but I doubt it.
Oh yeah the bar is rock solid.
Old Mar 20, 2004 | 12:09 AM
fended's Avatar
Dude I did mine in like 10 minutes on a lift at a friends shop.
Old Mar 20, 2004 | 02:34 AM
superjeer's Avatar
Is this wrong? Can someone measure that thing really well so I can rip it off and make one from 4130 tubing? I think it looks really solid, but I can make these things (with Daddy's help), seems like it'd be fun.
Old Mar 20, 2004 | 02:59 AM
why dont ya design your own :?:
Old Mar 20, 2004 | 03:20 AM
superjeer's Avatar
Holy crap! I write software! I can't make real things from scratch. Just pretend things. I suppose you're right though, I just liked the looks of this one, but I can make one in the spirit of this one and then everyone's happy I suppose.
Old Mar 22, 2004 | 04:18 PM
randode's Avatar
Wagonistas
ya mean like this?
killahXB2
Mar 27, 2015 10:45 AM
xa007xa
Feb 22, 2015 02:56 PM
AxRxP
Jan 25, 2015 08:40 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
tC6M
Dec 1, 2014 02:06 PM
