LSD Install problems for Echo Hatch
Old Aug 10, 2005 | 10:41 PM
ashtaron14's Avatar
Default LSD Install problems for Echo Hatch
The Echo Hatch in Canada has a C150N tranny
Now we had the tranny overhauled and found that the final drive had 6 bolts and that the LSD has 8 holes. Of course the holes don't line up.
The LSD that I purchased is TRD Part 41301-AW004. Now I was wondering if anyone have any ideas as to what I should do. Should I purchase the TRD final drive set with the 8 holes and pray that the output shaft will align with the gears (I am doubting it will). I am also curious if anyone on here knows if the final gear on the Scion has 6 or 8 holes (if there's 8 I might just drive down to US to find a tranny from a junk yard)
Thanks for your help
Sunny
Old Aug 11, 2005 | 03:37 AM
ashtaron14's Avatar
Here is a link to some pix of the tranny:
http://www.imagestation.com/album/?id=2122693247
Old Aug 11, 2005 | 11:42 AM
chucksu's Avatar
This is odd. I would think the Canada Echo, would share the same tranny as all the other echos, xA & xB along with most of those other crazy cars that came from that platform. Now the final drive is diff in some of the range, so that might make some difference. I think my first choice would be calling up TRD & seeing what the hell is up. If the LSD says it will fit a echo, then it should fit. If you already did that, what kind of answer did they give you? Sorry I cant be much more help.
Old Aug 11, 2005 | 02:24 PM
Ashe_WCM's Avatar
DeepSouth Scions
Not to sound stupid but do the 6 holes line up correctly with 6 of the 8 holes? if so you could just bolt it on using the 6 bolts and plug the other two holes.
Old Aug 12, 2005 | 12:41 AM
ashtaron14's Avatar
Nah man those are two totally different bolt pattern. I took a couple snap shots of the factory open diff and the TRD LSD. I'm gonna upload 'em tonite.
Do anyone happen to know what's the tranny code of the xA/xB? Pls let me know, thanks!
Yup we gonna contact the TRD dealer where I bought the LSD from.
Old Aug 18, 2005 | 10:49 AM
dgHotLava's Avatar
any updates???
mdhyre
Dec 7, 2014 12:52 AM
rcflyer15
Dec 5, 2014 05:15 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
