Spring Install Help
Old Mar 23, 2004 | 11:52 AM
rotarycolt's Avatar
Default Spring Install Help
I just wanted to know what to torque the different bolts to when re-assembling the suspension.
If anyone knows, please post!
Rear shock bolts....
Upper strut bolts....
The "BIG NUT" on the strut
The lower bolts on the struts
Lug nuts too if you know...
I think this would be a good post, since I've never seen it before and was curious.
THANKS!!!
Old Mar 23, 2004 | 03:59 PM
rotarycolt's Avatar
Randode? Anyone? I'm doing my install in the morning, and I'm sure I can make it all work properly myself, I just think im better off asking what I don't know.
Please? ;)
Old Mar 23, 2004 | 04:25 PM
randode's Avatar
Wagonistas
Default Re: Spring Install Help
Rear shock bolts....tight, but not over torqued (use a 17mm on a 1/2 drive ratchet)
Upper strut bolts....about 25 ft lbs. (use a 12mm wrench)
The "BIG NUT" on the strut (I use an impact gun and give it a few blasts, this should be tight)
The lower bolts on the struts (I use an impact gun and give it a few blasts, this should be tight)
Lug nuts too if you know... (i think its 55 ft.lbs., NO IMPACT GUN!!!)
Old Mar 23, 2004 | 04:52 PM
bBted's Avatar
usually u need 80-90 lbs for lug nuts
Old Mar 23, 2004 | 05:02 PM
Tamago's Avatar
for the lower strut bolts, 78-85 lbFT
Old Mar 23, 2004 | 05:50 PM
randode's Avatar
Wagonistas
I stand corrected. :D
scionlife
10
Mar 1, 2016 09:14 PM
ScionDP
Mar 1, 2015 10:57 PM
bBOXD
28
Dec 7, 2003 07:08 PM
randode
18
Nov 19, 2003 03:37 PM
randode
Sep 30, 2003 10:50 PM
