thick sidewall
Old Oct 15, 2003 | 03:38 PM
randode's Avatar
Wagonistas
Default thick sidewall
Im getting my fake 17" Volk wheels for my cherry xB this week. I know a 205/40/17 will work, but I really would like a little more sidewall since I will be driving on crappy roads to and from Hemet frequently. Will a 205/45/17 work? Eventually the car will be lowered 2" via Spy springs.
Old Oct 15, 2003 | 03:43 PM
scionaraxb's Avatar
How wide of wheels? I'm running 215-40-17's on 7" rims...........I remember seeing a post on here from a guy running 215-45-17's on 7" rims. I'll be putting 45's on mine when these wear out.
Old Oct 15, 2003 | 03:49 PM
randode's Avatar
Wagonistas
im pretty sure they are 7" wide
Old Oct 15, 2003 | 04:11 PM
scionaraxb's Avatar
check here.....
https://www.scionlife.com/forums/viewtopic.php?t=1882
Old Oct 15, 2003 | 04:15 PM
eric_m's Avatar
i think it's cool that you are getting 17s. 205/45 should work fine with those wheels.
this calculator will help you too maybe. http://www.miata.net/garage/tirecalc.html
Old Oct 15, 2003 | 05:03 PM
randode's Avatar
Wagonistas
that calculator is sweet. Is anyone actually running a 205/45/17? I dont want to get them and have them not work out, or look stupid or something.
Old Oct 15, 2003 | 05:48 PM
Kendo's Avatar
Default 17" tire sizes
The 215/40R17 is the proper size for the Scion. It has almost the exact overall height as the 185/60R15 stock size (only 0.03" taller). This is the size that will keep your speedometer and odometer most accurate.
The 205/40R17 is a little bit shorter, but still within spec. It is about a quarter inch shorter overall (0.28" shorter). When you have travelled 1,000 actual miles, your odometer will read 1,012 miles.
The 205/45R17 is a bit taller than stock. Usually when we do wheel and tire upsizing here at CEC we try and stay within 3% of OE size. The 205/45R17 is 2.21% larger than OE (.052" taller). When you have travelled 1,000 miles, your odometer will read 978 miles.
Old Oct 15, 2003 | 06:06 PM
scionaraxb's Avatar
one more thing.......IMHO the 205's are too skinny for 7" rims. My 215's are barely out to the rim sides, 205's look kinda small. I was thinking of maybe 225's the next time.
My 2¢.
Old Oct 15, 2003 | 06:13 PM
Kendo's Avatar
Default 205/215
The 215 will definately look nicer. The tire width itself should work though as a 205 tire is 205mm wide (8.07") and a 215 tire is 215mm wide (8.46"). A 225 will look better on a 7½" width rim or 8" rim.
Old Oct 15, 2003 | 06:16 PM
scionaraxb's Avatar
good info, thanks.
Old Oct 15, 2003 | 06:54 PM
randode's Avatar
Wagonistas
so i should get 215/45/17????
Old Oct 15, 2003 | 07:22 PM
nacy333's Avatar
Actually, I was very leary on getting 205's on my 7 inch width rim, but after looking at some wheel combinations, depending on the type of tire you get, it will be either flush or slightly wider than the wheel itself. The issue that you might have with 215/40 or 215/45 is that it will give that much more extra room to rub when you drop it. Personally, I'd try to go with a 205/45 for 17's.
Old Oct 15, 2003 | 07:30 PM
randode's Avatar
Wagonistas
I am probably going to go with some cheaper model Falken's. I'll have my wheels tonight, so unless anyone has any other suggestions I'm going with Nacy's idea of 205/45/17
Old Oct 15, 2003 | 07:40 PM
scionaraxb's Avatar
cheaper falkens? do you mean Visa's? (I heard Visa's were made by falken)
Anyway, I just went out and looked @my 215-40's on a 7" wheel. The tire is basically even with the rim side(sticks out maybe 1/16"). I'm think the 205's look "streched" onto a 7" wheel......but if you like that look , that's cool..and I could see how that might help eliminate a potenal rub if you slammed the car.
Old Oct 15, 2003 | 07:41 PM
scionaraxb's Avatar
BTW, my 215's are SUPER CHEAPO Hankooks! LOL!
Old Oct 15, 2003 | 07:46 PM
dchan8's Avatar
if i got 17's, i'd get 215/40/17's as this is the standard size the japanese bb drivers are using for 17's
Old Oct 15, 2003 | 07:52 PM
randode's Avatar
Wagonistas
yeah i think i would like the tire a little wider than the rim. I hate when the rim sticks out past the tire. So 215/40/17 it is. Unil someone else changes my mind again, which is totally possible.
Old Oct 15, 2003 | 08:04 PM
scionaraxb's Avatar
try looking @ arinvolvo's profile...he runs 215-45's and has pictures.
I'd be glad to let you look at my tires/wheels in person if it will help. I'm in Irvine right now.
edit..my bad......he used to have pictures
Old Oct 15, 2003 | 08:49 PM
ScionVan's Avatar
With a 17x7" high offset wheel, you should go for the 215/45 tire because the actual tire width and profile won't be as big an issue in terms of clearance. If you were going with a low offset, more flush wheel, that's when you gotta be a bit more judicious with your tire selection (and perhaps even stretch a narrow tire) to avoid any potential rubbing issues.
Old Oct 16, 2003 | 10:08 PM
randode's Avatar
Wagonistas
i got my wheels. They are 17" x 7" with a 40mm offset. So 215/40/17 or 215/45/17??? I hate this. I know I'm going to get the wrong size.
