Hotchkiss rear swaybar install tip
Old Mar 25, 2004 | 01:49 PM
jackmott's Avatar
Default Hotchkiss rear swaybar install tip
When I first started looking at this install I figured Id have to take it to a shop. You have to navigate a bolt that is just barely small enough to fit, way way inside the rear trailing arm, and drop it into a tiny hole. No way to reach with your fingers. If you have some really long nosed pliers that *might* work.
What I figured out - take a 13/14mm or so wrench, lay the bolt in it, then tape the bolt on so it wont slip off.
Then you should be able to get the bolt in the control arm sideways, then twist it around to vertical, and then hunt around until you get it to drop in the hole.
then just tear the wrench/tape off.
Old Mar 25, 2004 | 01:59 PM
mikochu's Avatar
Cool... Someone (*ahem* look in the mirror) should do a walkthrough on how to install the sway bars so scared DIYers like me can be more confident in installing the sway bars.
To get screws in in hard-to-reach places (without using two hands), I used to use tissue (kleenex) to hold the screw on the screw driver... Now I use those long flex screwdrivers that have a bit that expands and contracts to hold the screws.
Old Mar 25, 2004 | 02:39 PM
HOLLYWOODSOUNDS's Avatar
Default sway bar bolts
easy............... just put a wire threw the opening and then tape the bolt to the wire then pull.
Old Mar 25, 2004 | 02:43 PM
tbblizzard's Avatar
that's the rear... don't you gotta lift the motor to get to the front? i think it's more work than that.
Old Mar 25, 2004 | 04:21 PM
jackmott's Avatar
Default Re: sway bar bolts
I tried that with some string at first, tying it, but the knot kept coming lose =)
didn't have any wire =)
jackmott's Avatar
I dunno
haven't done it.
Old Mar 25, 2004 | 04:43 PM
I used my Mac tools extension magnet to put the bolts in their place and blasted the nut on with my Snap-on Airgun. But I wanna see the DIY on the front swaybar, thats a challenge a lot of people want to see.
Old Mar 25, 2004 | 05:13 PM
dinkjs's Avatar
Do you think it would be a much easier job for someone who has not lowered there car yet to just put the front sway bar on when they are putting new springs on?????
Old Mar 25, 2004 | 07:18 PM
jackmott's Avatar
no
the difficulty mainly lies that there is tons and tons of crap you need to take off from under the car to get the old bar out and the new one in.
ive only looked at it briefly and thought "Damn!"
I may try in a few weeks to DIY and I'll post if I do
Old Mar 25, 2004 | 08:24 PM
no
ok, when lowering your car, you take out the strut. When installing the swaybar, you need the strut to hold the subframe. So, yeah no. Don't lower the car at the same time as the swaybar install.
The DIY instructions will be in full detail, because I am using air tools and a lift. And it still takes me 2 hours to install the dam thing.
killahXB2
Mar 27, 2015 10:45 AM
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
