My cel keeps coming on.
Old Sep 18, 2005 | 11:54 PM
miamibusta69's Avatar
Default My cel keeps coming on.
Ok i have k&n intake and AW headers and after i installed the headers with the antifouler my cel keeps coming on i just jeep restarting my ecu to get my gas milege back.. What should i do to fix the problem the .. it comes back on like every 200 miles after every restart.
Old Sep 18, 2005 | 11:56 PM
The_Instigator's Avatar
Are you sure the CEL is from the anti-fouler and not some other problem? If your mileage is bad, it sounds like the main O2 on the header is acting up. The second O2 shouldnt affect richness (a/f) at all.
Old Sep 18, 2005 | 11:57 PM
lvnurs9's Avatar
place the anti-fouler on the O2 sensor in the s-pipe instead of the header...supposedly that works
Old Sep 18, 2005 | 11:58 PM
XD40tC's Avatar
Are you certain your mileage is bad when it comes on cause if so then yes its the first one. Me thinks...
XD40tC's Avatar
Well thats how its supposed to be in the first place!
matty-tC's Avatar
whoa whoa whoa...
NEVER install the antifoulers on the header. NEVER
I've seen this on the forums quite a bit lately. I really hope you guys realize its the 2nd sensor on the exhaust side (go look at your s-pipe) that is throwing the CEL in the first place.
Old Sep 19, 2005 | 12:02 AM
Kaeon's FAQ : https://www.scionlife.com/forums/viewtopic.php?t=56520 has the anti-fouler trick outlined perfectly. If you follow these instructions you should not have a CEL. If you do have a CEL and have followed his FAQ, then it is likely there is some other problem and you should get the car scanned to see what is really going on.
Old Sep 19, 2005 | 12:08 AM
lvnurs9's Avatar
Originally Posted by matty-tC
whoa whoa whoa...
Like I said I was under the impression people were not doing this...thats why I said that. Maybe I was wrong.
Old Sep 19, 2005 | 12:36 AM
PghtC's Avatar
OMG!!! I cannot believe people would put anti-foulers/spacers on the primary O2 sensor!! Crazy.
Old Sep 19, 2005 | 01:50 AM
I did put it on the header 02 sensor. But I took it off and put it in the right place. and it is still going off. I just hope the sensor is not broken. Ive heard its alot of money.
Old Sep 19, 2005 | 02:07 AM
danman04x's Avatar
what will happen if you do?
Old Sep 19, 2005 | 02:11 AM
zoltiz's Avatar
N.G.S.O.
Read the DTC that causes the CEL, then try to fix it. CEL does not have a universal solution - it can be triggered by a lot of things.
Old Sep 19, 2005 | 02:12 AM
Um i have to pay for it.
Old Sep 19, 2005 | 02:14 AM
zoltiz's Avatar
N.G.S.O.
Autozone here does it for free.
Old Sep 19, 2005 | 02:40 AM
No i know that i meant if the o2 sensor is broken then i would have to buy a new one and i hear they are expensive... cuz thats what i think it is i hear they are sensitive... and my uncle who installed it is not.
Old Sep 19, 2005 | 02:47 AM
Make him pay for it then. Im sure he will like that
Old Sep 19, 2005 | 02:49 AM
zoltiz's Avatar
N.G.S.O.
Well, diagnosing what's wrong just by the fact that you have a CEL is like saying "I don't feel well, how do I get better?".
So let's try to figure out what the problem is first, and then worry about prices of O2 sensors these days ;)
Old Sep 19, 2005 | 03:18 AM
ZPIracing's Avatar
Get the code and give us a call we maybe able to help. We stock both 02 sensors if you need one. The front 02 shoudl not throw a CEL unless it is faulty regardless of A/F. The rear sensor does chane the gas mileage although it is not a wide band if it reads excessive flow it will dump fuel to compensate.
Old Sep 19, 2005 | 03:47 AM
Souljah347's Avatar
which o2 did you use the antifouler on. it needs to be on the s-pipe i think. someone correct me if i'm wrong
Old Sep 19, 2005 | 08:40 AM
HondaKiller's Avatar
ive been haveing the same problem. the CEL comes on sooner and sooner everytime. .before it came on every 1000 miles or so with just 1 antifouler..so i put 2 antifoulers on and it comes on within 20 -50 miles..and i noticed when i changed from 91 octane to 89 it started showing up sooner..and my milage went from 32 to about 25 or worse..ive had my car scaned 2 times at autozone for free, and both time i got the same code p1036 bank 1 sensor 2. did you drill your antifouler out to 1/2 inch? i have the drilled out one screwed into the regular one and it still dont work. and the added length of 2 antifouler makes the o2 sensor hit and rattle on something under the car when i put it in reverse which i think might of damaged it. but i think im going to buy a new o2 sensor when the spipe gets here and try over again
