I am looking for a full Air Ride Setup I can buy that i can put in my xB. Can I get a few sites and insite on if the set-ups the way they are decent and reliable as they are? Please help me out in this area as I am trying to order a set-up in the next couple weeks.
www.fbimini.com and www.suicidedoors.com for all your air needs. Want to go the cheap and efficiant way, where you will have a good set up and get everything at good prices, they are the ones you wanna go with. Or spend your money on the name of air runner and get basically all the same stuff but struts for more than half of what the same stuff costs.
Sittin' low in Sittin' Pretti.
If you ain't sittin low, you ain't Sittin' Pretti.
Then of course line, fittings, gauges, valves (40$~), tank prolly some other sheit too i'm forgetting, should be under 1500$ and i'll try to install it myself
oh yea, i'm only going to run a FB setup, haven't found a reason to run FBSS yet
I really like Viair and such, but they pull a lot of current from your battery and can cause some wiring problems, so when doing it, make sure you use good size gauged wire.
its not about where you mount it. Its the amount of amps the compressor is pulling. Just make sure you are running a fuse and the right size gauged wire.
Hey Rebel Man check out www.gravity-werx.com he can get you the front struts from ES a lot cheaper then that If i remember it there around 500
Never even heard of that company. I'll stick with a name I know and trust.
Remember at 1 point in time viair was an unknown! Air-zenith is a new company. There product is very impressive. I am happy with my choice and you are happy with yours. see everyone is happy
