problems getting in to second gear
Old Apr 1, 2004 | 12:26 PM
urban_assault_XB's Avatar
Default problems getting in to second gear
I'm going to the track sat and I know nothings wrong with my trans but is it just me but is hard to get into 2nd gear its like the shift has a know that you have to pass before you can get in to 2nd this causes me to miss 2nd some times when shifting fast. Does the short throw fix this problem also I ran 17.53 last time with out my exaust does any one think that my cat back will make a diffrence thanks.
Old Apr 1, 2004 | 01:26 PM
Tamago's Avatar
you're missing second cuz you're shifting too fast.. slow down, take your time.. it's an 18 second car man, .01 seconds slower on a shift won't really make you the laughing stock of the track.
no, the exhaust won't help.. you may trap a higher speed, butyour time will be similar.
Old Apr 1, 2004 | 03:33 PM
rotarycolt's Avatar
Well, you could try driving better... thats dirt slow for an xB, it should be a full second faster. My car does 0-60 8.6s 1/4 mi in 16.4's stock.
Old Apr 1, 2004 | 03:34 PM
Munch's Avatar
If he's missing 2nd gear then I can see why his times are slow.
Old Apr 1, 2004 | 03:42 PM
tbblizzard's Avatar
what's both your guys' speed when you hit 1/4 mile mark?
Old Apr 1, 2004 | 05:21 PM
welcome to the lagging second gear club. My does the same thing, I have to slam it sometimes when I am racing someone. Its the tranny design I think, its always been that way since I got the dam thing. I thought it would loosen up after a few thousand miles, but no 2nd gear is a pain.
And its not the matter of not knowing how to drive, it can be a tranny problem too. remember that we are the first generation here in the US and they might have changed a few things when it was tranferred from the JDM market.
Old Apr 1, 2004 | 06:36 PM
TheScionicMan's Avatar
Mine always shifts into 2nd just fine...
Old Apr 1, 2004 | 08:57 PM
YOU SUCK MARK, I'm gonna kick you in sac when I see you!!
Old Apr 1, 2004 | 09:52 PM
As long as you don't kick me in THE sac...hehehe
Just defending my homeboy, the Automatic! It gets less respect than an xA...
Old Apr 1, 2004 | 10:47 PM
silkywilson's Avatar
I cant rip it into 2nd gear either.,.. it gets jumbled up between them if Im trying to be fast on the 1,2 shift.. but only 1,2 none of the others...
Old Apr 1, 2004 | 11:00 PM
Rayman's Avatar
Yeah same problem here. If I try to go fast from 1 to 2 it's difficult to shift. If you take it easy though it does shift smoother but not as fun.
Old Apr 1, 2004 | 11:25 PM
scionxb04's Avatar
i only have problems with 2nd to 3rd....i can bark the hell out of 2nd on 18's....shoulda seen stock tires....didnt get traction.....
try slowing down your foot.....you might be letting the clutch out to soon
Old Apr 2, 2004 | 03:25 AM
XBman's Avatar
a hahahah
Old Apr 2, 2004 | 06:43 AM
I'm clutching just fine. It's the 1 to 2 shift the rest are fine I can doublre clitch and it 'll run but I now I could be faster and about my time car and driver tested an auto and it ran like 18.3 or something but it was in the 18's. does any one know if the TRD short shifter fixes this prob I figure its either a crappy shifter linkage design or the plastic style shifter or lastly the trans if any one know about the short shifter holla
Old May 5, 2004 | 06:04 AM
kalieaire's Avatar
anyone try a new transmission oil?
Old May 5, 2004 | 02:07 PM
ahurdl01's Avatar
my tranny is just sloppy. I have a lot of play when it is in gear. I do get teh feeling that gears 2-5 are spacing evenly, but it seems like 1 and 2 are a little off, probably to give more torque in first , cuase the car has no *****.
Old May 5, 2004 | 03:31 PM
Sciomodr's Avatar
I was going to suggest the same thing. My experience with DSMs in the past says to at least give it a try, Redline and BG both made an oil that made the horrible-shifting dsms shift poorly, but at least it was an improvement :D
Mike
Old May 5, 2004 | 05:13 PM
Tamago's Avatar
i'm currently running mobil1 synthetic trans oil.. much smoother shifts.
that first to second shift will always be difficult. remember, you've gotta get those synchromeshes up to speed.. the 1-2 shift is the most difficult on the transmission because it generally has the largest gap in ratios.
shortshifter will not help.. it might actually harm more than help.
that being said.. i couldn't live without my shortened TRD shifter :D
Old May 6, 2004 | 03:30 AM
Did changing the transfluid really work? How many quarts did you use?
Old May 6, 2004 | 12:28 PM
Tamago's Avatar
well, i have a corolla, different transmission, so i used 1 qt. look in your owners manual. the specs are in there.
