Mine does that too...only when it's cold...then once you have driven a bit it stops...i guess it's normal since there's a lot who have this issue. I was going to take it in for that...but since it only does it in the morning...by the time i drove it down there it would be fine...so O WELL!
i usually warm up the car a little, then press in the clutch and run it through all the gears a few times to shift around the fluid...sometimes it helps
Creative Compacts short shifter
Corsport shifter cable bushings
Redline MT-90 Synthetic Trans fluid swap
Monsterknob shift ****
Redout reverse & 3rd brake lights
Aux input box
autoalarmpro alarm
yah it JUST started gettin cold here in FL....liek 38 degrees last night....and even tho i park in a garage, shifting into reverse, then 1st, then 2nd is a lil sticky. but after i get to the front of the neighborhood is all good.
