5 lug conversion?
Old Oct 21, 2003 | 04:18 PM
TheRedBox's Avatar
Default 5 lug conversion?
I'm thinking about trying to do a 5 lug conversion. Problem is I don't know what's involved and what's needed/what will fit. Maybe parts from a Celica? Or maybe a camry? :?:
Old Oct 21, 2003 | 05:34 PM
randode's Avatar
Wagonistas
if you want to go with 5 on 100 mm, you can use one existing stud and drill the remaining 4 holes in each hub and press in the studs. Your rotors and drums will also have to be re-drilled.
Old Oct 21, 2003 | 09:20 PM
ScionVan's Avatar
The only real advantage to going 5 lug on most 4 lug cars is to be able to draw from a much larger variety of wheels. This is especially true in the case of Nissan 240SXs, for example, because you can get wider, and lower offset wheels in 5x114.3mm, whereas it's super hard to find the same fitment wheels in the standard 4x114.3mm bolt pattern the cars come with. On the Scions, if you switch to a 5x100mm bolt pattern, not only are you NOT increasing your wheel fitment options, but most readily-available 5x100mm wheels are actually WORSE because they're the +50mm wheels made for the Subarus. In fact, most wheel manufacturers offer lower offsets for 4x100mm wheels than 5x100mm wheels because the only JDM cars that use the 5x100 are the Subarus (and to some extent, the Celica, which isn't very popular in Japan anyway).
Old Oct 22, 2003 | 12:12 AM
Kendo's Avatar
Default 5×100
True that most of the 5×100 PCD Japanese cars are high offset, but don't forget the VW's. Tuning wheels for the VW Golf 4 GTi, VW Jetta 4, Audi TT will fit. Other 5×100 fitments include: Toyota Matrix, Dodge Neon, hmm... I'm sure there are others too...
Old Oct 22, 2003 | 12:19 AM
scionlife's Avatar
Founder
I'm doing a thirteen stud conversion. I figure the more studs, the better, right?
<grin>
But seriously, the five-stud conversion thing is more of a status thing than anything else. I mean, seriously, when is the last time you heard of someones wheel breaking off because they were rallying with the standard four-stud setup? When you were rolling a 92 Civic hatchback with the five-stud conversion everyone knew (or thought) that you had the Type-R suspension on the car... I think that is probably the most obvious status symbol for that conversion anyway... (yeah, the 240SX had both, but it wasn't as cool since the SEs came with 5-lug anyway)
I would do the conversion if I had some cool wheels...
Darren
Old Oct 22, 2003 | 12:27 AM
its_ikon's Avatar
i would spend the money other places. it will do nothing for the car.
Old Oct 22, 2003 | 07:47 PM
TheRedBox's Avatar
It was just a thought. I found some dope ___ rims that i wanted, and figures I could have exclusive rims and be the first with a 5 lug conversion. but after talk to some people, it looks like that is dayam well not going to happen. Unless of course, you guys would like to contribute to the "my car has 5 studs and yours only has 4" fund.
Old Oct 26, 2003 | 06:58 AM
Slopoke21m's Avatar
bad news....the rear hubs have 4 "spokes" that the wheel studs are attached to, so there is no room on them for 5 holes.....at least using stock hubs, dont know how the fronts are yet. See Ya, Louie
Old Nov 19, 2003 | 03:12 AM
HotBox's Avatar
i to had this idea... i was thinking of using the celica gts disc brakes all the way around because i want 19in TE37s. i was just wondering can it be done?? im sure its possible but i wanted some info before i actually started to try. oh and if im able to do it would i need to buy the suspension parts for the scion or for the celica? any info would be much appreciated. thanks
Jason
Old Nov 19, 2003 | 03:16 AM
HotBox's Avatar
hopefully i made sense becuase these sleeping are kicking in so im not sure but ill check back tomorrow just in case i didnt thanks again
Old Nov 20, 2003 | 05:05 PM
TheRedBox's Avatar
You can do it. just takes time and $$$$$$$$$$$$$$$4
Old Nov 20, 2003 | 05:32 PM
HotBox's Avatar
stupid me... i just realized that many civic owners did the typeR 5 lug conversion (havent paid much attention to hondas anymore getting old ) so if they can why cant we.. i cant believe i didnt remember that but yeah anyways the thing that still puzzles me is after the task is complete would you buy the suspension parts for the xb or the celica??
Old Nov 21, 2003 | 01:32 AM
ScionVan's Avatar
Unfortunately, even swapping to Celica 5 lug hubs won't help you there because the 19" TE37s are only available in a 5x114.3mm bolt pattern, whereas the smaller Toyota cars with 5 lug have a 5x100mm bolt pattern.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
eujin
Feb 23, 2016 01:18 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Renuco612
Sep 16, 2015 09:01 AM
