Stock Rim Weight???
Old Nov 11, 2005 | 07:13 AM
PT's Avatar
PT
Default Stock Rim Weight???
Hey I was curious if anybody knew how much the stock rim weighed because I when I upgrade I want something lighter and that looks better. Thanks
Old Nov 11, 2005 | 03:37 PM
The_Instigator's Avatar
I was talking to Raamaudio about rims and he says the stockers are around 19lbs...which is pretty good.
Old Nov 12, 2005 | 08:08 AM
PT's Avatar
PT
Thanks finally someone answers me! I've been trying to find this out for a long time. wow 19lb is lightweight so not much to upgrade from here unless I go with 16s which I wont. Thanks man
Old Nov 12, 2005 | 04:40 PM
Batjew's Avatar
i forget, 21 or 22lbs, you should've searched first.
Old Nov 12, 2005 | 05:10 PM
hahaitzskippy's Avatar
i thought it was 19bs and the tires lik about 20 lbs? watver im pulling numbers outta my ****
Old Nov 12, 2005 | 05:15 PM
DJ_X_Trodinaire's Avatar
info can be found in the thread and butter
Old Nov 15, 2005 | 12:53 AM
tCb00b's Avatar
When I had a set of stock wheels and tires shipped to me the weight for 2 wheels with tires was 82lbs. The tires had 15k miles of rubber off of them so I duno what that weight is. So thats 41lbs per wheel and tire, I think. But I will weigh them when I get the new tires mounted up.
Old Dec 21, 2005 | 04:21 AM
SpdLmtNA's Avatar
so does anyone have an answer to this... andI doubt each rim weighs 41 pounds...
Id personally like to know the weight without tires...
Old Dec 21, 2005 | 12:43 PM
06tCguy's Avatar
he said rim and tire.
Old Dec 21, 2005 | 01:11 PM
SpdLmtNA's Avatar
Even with both, I still doubt each one weighs 41 lbs... theyre aluminum first off, and how much do these low profiles weigh... def. not in the 20lb range
Old Dec 21, 2005 | 03:48 PM
06tCguy's Avatar
http://www.tirerack.com/tires/Spec.j...ama&model=S32A
http://www.tirerack.com/tires/Spec.j...omCompare1=yes
23lbs... :D
Old Dec 24, 2005 | 04:24 PM
Jimmy's Avatar
pretty light for it being stock.
Old Dec 24, 2005 | 04:30 PM
Nick06tC's Avatar
This should prove it. I took pics of my stock and my 18's to see the difference.
And my 18's
So yeah tire and wheel about 41 lbs
Old Dec 24, 2005 | 04:32 PM
Nick06tC's Avatar
oh and this is with 100% tread I only had maybe 400 miles on the car when I installed them
Old Dec 24, 2005 | 06:42 PM
simplespirit's Avatar
Stock wheels are 17x7", 5x100 PCD, +45mm offset and 22 lbs.
The Potenzas on the first tCs are 215/45R17 and weigh 23lbs.
Total combined weight is 45lbs.
Old Dec 24, 2005 | 07:10 PM
Nick06tC's Avatar
not to dispute it, but if you look at my postabove, I have them sitting on a scale. They are about 41 lbs
Old Dec 24, 2005 | 07:51 PM
No two scales are the same. Was your scale properly calibrated before you took your measurement? What's the percentage of error on it? And I'm guessing it's a bathroom scale, which is designed for measuring body weight. I didn't weigh them myself, I'm going off what the respective manufacturers have said they weigh.
Old Dec 24, 2005 | 07:56 PM
Munch's Avatar
Oh boy here we go again. Even with soild truth sitting on the computer screen. People still have to dispute it. I guess it's the scionlife way
Old Dec 24, 2005 | 08:19 PM
Nick06tC's Avatar
Man, I forgot to call in the nuclear physisit to properly calibrate my bathroom scale. Plus it was kinda windy in my bath room so it may have been exerting a force on the tire causing it to way more.
Plus the dealer might have used a special air to make the tire lighter.
Man I probably wont weigh myself anymore, i dont want to be fooled about what my true weight is on my non precise bathroom scale.
THIS IS WHY I SOMETIMES CONSIDER NEVER POSTING ON THIS WEBSITE. No mateer what anyone says or what they post, someone will say its wrong or off, or not true.
ITS A SCALE. IT TELLS WEIGHT. ITS A PICTURE. WHAT MORE DO YOU PEOPLE WANT.
Yes i used caps, and thats because i am yelling.
Old Dec 24, 2005 | 08:20 PM
Nick06tC's Avatar
ohh and the manufaturers info is always 100 percent correct. I forgot about that. No one is ever off on weight, HP or anything.
