OFFSET.. What it is?
Old Nov 22, 2005 | 02:35 PM
Match_Box's Avatar
Default OFFSET.. What it is?
I know is probably stupid but what does the offset means in the wheels?
Ive read about 25 offset, 45offset etc...but what does that number represents?
The lower/higher the offset, what does it means?
Please enlighten me cause i dont have a clue..
thanks
Old Nov 22, 2005 | 03:30 PM
stick_1NZ's Avatar
you'll find all the info. here:
https://www.scionlife.com/forums/viewtopic.php?t=348
please take advantage of the feature next time.
Old Nov 22, 2005 | 04:14 PM
RTon20s's Avatar
A simple answer could suffice just as well as a condescending pointing to the search option.
Offset is the distance in millimeters that the mounting surface of the wheel is from center. A positive offset is closer to the outside of the wheel. A negative offset is closer to the inside of the wheel.
Another term you may here is "backspacing." This is similar, but not the same. Backspacing is the distance from the back of the wheel to the mounting surface. One thing to keep in mind when talking about wheels is that they are actually wider than what the specifications call them. For instance an 8" wheel is actually 9" when measured from outside of lip, to outside of lip.
Hope that helps.
Old Nov 22, 2005 | 04:24 PM
sexyscionlover's Avatar
No actually, Ned was right. People need to utilize the search that is there. Ned was even nice enough to post a link. I thought he did well.
Since you have the info, this is locked
greg_jspec
Scion tC 2G Wheel & Tire
Apr 21, 2012 04:16 AM
jelder11
May 10, 2010 10:44 PM
gonzodavidj
Scion tC 1G Wheel & Tire
Apr 30, 2007 06:23 PM
NewMexicoxBPhatBoy
47
Jan 12, 2007 02:13 PM
NewMexicoxBPhatBoy
11
Nov 2, 2006 06:22 AM
