Register Forgot Password?
Reply
Old 12-02-2005, 02:47 AM   #1
JDMJim
JDMJim's Avatar
JDMJim 40/M
Default tC trans slipping.
We ahve a tC with the auto trans. 37k on the clock. second winter. This Q is aimed at other cold area owners. I have begun to notice the transmission "slipping on a 2-3 shift. It just doesn't "feel" right. Any thoughts?
JDMJim is offline   Reply With Quote
Old 12-02-2005, 03:00 AM   #2
HondaKiller
HondaKiller's Avatar
HondaKiller
same here..i only have 24000 miles on the car and ive noticed the same problem here in washington when it gets down in the 30s..im going to the dealership in a week to get it checked out .im due for a tranny service anyway, and after that im going to do a full synthetic swap wich some people say should help out in cold weather
Live to Burn...Burn to Live
HondaKiller is offline   Reply With Quote
Old 12-02-2005, 04:01 AM   #3
JDMJim
JDMJim's Avatar
JDMJim 40/M
At least I'm not alone. thanks. I'll have it checked with the recall work.
Old 12-02-2005, 03:22 PM   #4
jaewon223
jaewon223's Avatar
jaewon223 113/M
Send a message via AIM to jaewon223
hope it gets fixed, keep us updated
Behind every good scion driver, lies an empty gas tank.
jaewon223 is offline   Reply With Quote
Old 12-02-2005, 06:10 PM   #5
smash
smash's Avatar
smash 28/F
Send a message via AIM to smash
i've already got full synthetic in my car.. it helps a little, but i still notice a bit of a shudder from start to first. maybe i'm just retarded but i don't think so. my car has 34,000 on it and the clutch was squeaking/making metallicy noises beginning the first few months I owned it.
Girls can drive stick too; only, we look sexier when we do it.
http://www.myspace.com/imadefriendswithmyfast
http://www.cardomain.com/ride/2045465
smash is offline   Reply With Quote
Old 12-02-2005, 11:12 PM   #6
sciontc_mich
sciontc_mich 113/M
Default Re: tC trans slipping.
Quote:
the other thing to notice is if it's only doing it when it's cold.. because the tC does have a mode where it will NOT shift into the top gear when it's cold.. it does this to warm up the engine.. The auto transmission is programmed to work differently when it's cold.. Does it still slip when it's warm??
The powertrain includes the transmission and that is covered for 5yrs/60k miles.. if it does it when its warm i would take it to a reputable dealer and get it checked out..
sciontc_mich is offline   Reply With Quote
Old 12-07-2005, 02:22 PM   #7
C_Money
C_Money 113/M
Send a message via AIM to C_Money
I'm actually having the same type of problem. When its cold, my TC will not shift into top gear until the engine warms up. SCIONTC_MICH you said that the TC has a mode where the TC will not shift into top gear when its cold Is this for a manual or auto trans? I have an auto trans that shifts fine once the car warms up. I just thought it was weird that it will not shift because of the temp.
2005 Scion TC - SILVER STREAK MICA
**Team ScioNRG - Website**
http://www.teamscionrg.com/
C_Money is offline   Reply With Quote
Old 12-07-2005, 03:11 PM   #8
dsaint17
dsaint17 34/M
Send a message via Yahoo to dsaint17
Try to shift the gears while you are at stop before driving ... and let the engine warm up for at least 5 minutes, especially that you live in a very cold state. Where I live the weather is extreme, that is why before i leave, i shift the gears all the way to reverse and that should warm it up.
dsaint17 is offline   Reply With Quote
Old 12-08-2005, 12:04 AM   #9
sciontc_mich
sciontc_mich 113/M
Quote:
hey c_money.. yeah the tC has this mode where it will not shift into the top gear (4th gear) when it's cold.. it does this to warm up the engine quicker to heat up the catalytic convertor quicker.. yeah it only does it when it's cold.. completely normal..
this is for the automatic..
Old 12-08-2005, 11:45 AM   #10
C_Money
C_Money 113/M
Thanks bro, it's more of an annoyance than a problem. Trying to pull onto the turnpike, while the car won't shift to top gear just sucks. I'll just have to let it warm up a little longer.
Old 12-08-2005, 12:51 PM   #11
06tCguy
06tCguy 27/M
Send a message via AIM to 06tCguy
yeah, my corolla did that, too. it's to heat everything up..engine, trans, cats, etc. it will shift if you go a certain speed, though..my corolla wouldn't shift into third until about 30mph or so.
06tCguy is offline   Reply With Quote
Old 12-11-2005, 06:09 PM   #12
JDMJim
JDMJim's Avatar
JDMJim 40/M
Got the shifting part figured out, but still I get that hesitation when going from 2nd to 3rd or the down shift in stop and go traffic. It just doesn't want to go.
Old 12-11-2005, 07:22 PM   #13
eric06303
eric06303 113/M
my car has about 46k on it now and i've already had to change the tranny once...changed it at 35k, i felt the slip between 2nd and 3rd and also when i put the car in reverse
eric06303 is offline   Reply With Quote
Old 12-11-2005, 07:52 PM   #14
Glazebrook
Glazebrook 28/M
Send a message via AIM to Glazebrook
If you don't do it already, starting the car a few minutes before you actually leave might be a good idea. My tC hasbeen running fairly normal throughout all the weather we've had in the teens and twenties. The engine is usually ready to go after about 10 minutes. Anyways, just a suggestion.
Scott
Miami University '07
Advance Auto Parts, Hamilton, OH - (513)-844-1100
Glazebrook is offline   Reply With Quote
Old 01-09-2006, 11:53 PM   #15
LED-Maniac
LED-Maniac's Avatar
LED-Maniac
you shoulnt be driving in top gear on a cold engine anyway....correct me if im wrong but this will wear parts out quicker if they arent sufficiently lubed up and already working at high rpms
___________________________
LED-Maniac is offline   Reply With Quote
Old 01-10-2006, 01:50 AM   #16
tcva
tcva 28/M
wow same here.
when it 40 below.. the tran slips when i pass the 15mph mark..
it's like this tingling sound .. but it goes away once the car runs for about 10 minutes..
very wierd. i have 24k miles on it too.
tcva is offline   Reply With Quote
Old 01-10-2006, 02:14 AM   #17
SciontCya
Big Sky Scion
SciontCya's Avatar
SciontCya 52/M
Send a message via AIM to SciontCya
When I lived in PA, and had autos, they did that sort of thing. It's not too hard to see why if you look at how an auto works.
Maybe synth fluid would help there?
Scott
SciontCya is offline   Reply With Quote
Old 01-10-2006, 03:46 AM   #18
camys_daddy
camys_daddy 47/M
Do you guys who are putting synthetic transmission fluid in your trannys know that Toyota spec's a special tranny fluid.
The Toyota spec is type T-IV
I believe Amsoil claims to have a synthetic that meets this standard and Mobil ATF 3309 claims to meet it.
If I had an automatic, I WOULD NOT use Mobil1 Synthetic ATF or any others unless it claimed to meet Toyota Type T-IV specs.
HTH,
T
camys_daddy is offline   Reply With Quote
Old 01-11-2006, 02:43 PM   #19
camys_daddy
camys_daddy 47/M
What, no comments on the tranny fluid?
Does that mean all you guys who put Mobil1 tranny fluid in your automatics are rushing out to change to the correct fluid?
I'm not dissing on M1 tranny fluid, it's a good fluid in the right box. It's just not made for this application.
Comments from the peanut gallery?
Old 04-14-2006, 08:37 AM   #20
bB2NER
Music City Scions
bB2NER's Avatar
bB2NER 109/M
Send a message via Yahoo to bB2NER
Yes, You are correct camys_daddy. I just did a bunch of research on this whole ATF scam that Toyota has going. The Toyota T-IV Fluid is almost as expensive as the Amsoil full synthetic. I'm just going to buy a case of the Mobil 3309 and change the fluid every 15K or so. It's about 2 bucks cheaper a quart than the Toyota stuff and it's compatible.
I just changed it out at 25K and it was smelling pretty nasty for such low miles.
Jeff
05' BCP xB W/ 48K miles
08' Absolute Red Yaris LB 5spd. W/ 42K miles
bB2NER is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
05, hard, plasmicxtc, scion, shift, slip, slipping, tc, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
