Offset questsion
Old Dec 7, 2005 | 01:45 AM
IndigoDreams's Avatar
Default Offset questsion
im chaning out my 17's on my tc and wanted to know with a 17x7 rim should i go with a +40 or +48 offset i want it to look as flush as possible and not sure how offsets work
Old Dec 7, 2005 | 01:59 AM
The_Instigator's Avatar
Youll want to go with the lower number offset to push the wheels further out. Im looking at a 17x8 in a +35 offset for my car to ensure clearance for my big brake kit.
A good way to look at is that the +40 offset will stick out 8mm further than the +48mm offset.
Old Dec 7, 2005 | 03:38 AM
DuMa's Avatar
i have 17x8 +32 and its pretty flush all around. well it would be flushed whenever i decide to get an damn alignment.
that is around 18mm-23mm wider than stock. the length that stick outs depends on the tire size you get. if you went with 235/40 with my set up, it would stick out 23mm. if you went with 225/45, it would stick out 18mm. imho the right length to get it flush is around 20-21mm difference from stock.
stock is 17x7 +45 so in order to get it flush with 17x7 wheels, you need to get it a +25 or +24 offset with those wheels.
its generrally harder to get those offsets on a small width wheel such as 7" so you'll have to look in the 17x8 and 17x8.5 variety.
also if ur still confused. try using this calculator
http://www.rims-n-tires.com/info_spe...20/%20Comparer
hope i helped out
Old Dec 7, 2005 | 05:08 AM
Motorsport_TC's Avatar
I used to run 18x8 with a 32mm offset which ran fine
Old Dec 7, 2005 | 05:18 AM
-Keith-'s Avatar
I run a 18x8.5 with a 35 just perfect
Old Dec 7, 2005 | 11:08 AM
neither one of u guys except for the first person to respond accually read my questsion, I said with a 17x7 wheel which offset will look the most flush the 40 or the 48 thats all i asked and since the 40 will pull i t out more thats what i need.
Old Dec 7, 2005 | 02:55 PM
-Keith-'s Avatar
Sorry... 40 will put you closer but still will not be flush.
Old Dec 9, 2005 | 12:13 AM
JdtC3713's Avatar
^^ yup, you should get atleast +35. i currently have 18x7.5 +35 with 225/40. looks really good with my drop. :D
Old Dec 14, 2005 | 08:00 AM
boostedscion's Avatar
this is an awesome post.. That link up there is very helpful!
Old Dec 14, 2005 | 11:34 PM
yamaha16bw's Avatar
Can anyone of you guys post pics so we can see how different offsets line up?
Thanks alot for the good info!
xBrelease08
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
