belt slipping?
Old Dec 21, 2005 | 10:32 PM
madigan923's Avatar
Default belt slipping?
anyone who has the ZPI pulley experienced any belt slipping? Im getting real low boost for high RPM... like 4psi. I just cant think of anything else that it could be. I reinstalled the stock one and it worked fine. then put the pulley back on and same as before.. 4-5 psi max. any info would be great.
Old Dec 21, 2005 | 11:14 PM
Stock's Avatar
i have full boost at like 3800 rpms (9ish lbs) No problems... might be the way you shimmed your pulley
Old Dec 21, 2005 | 11:15 PM
Stock's Avatar
hows your belt tension?
Old Dec 21, 2005 | 11:18 PM
Stock's Avatar
sorry for all the posts but also could be a defective spring in the BPV... and that would be able to make it able to hold stock boost and not the upgraded boost level. Hope all this helps
Old Dec 21, 2005 | 11:19 PM
jrv2000's Avatar
this can be fixed by replacing with a bosch 110 bpv
Old Dec 21, 2005 | 11:22 PM
Stock's Avatar
you should of got a warranty with it so check with the place you got it from and see what they will do for ya... If not call up Bosch.
Old Dec 21, 2005 | 11:27 PM
madigan923's Avatar
i guess i could try the stock BPV to see if my 110 is defective.. but i doubt it...
there were no shims on my pulley.. and since i swapped my stock pulley back and it worked tells me that its not the install. im gonna check tomarrow for any belt wearing due to slipping.
Old Dec 21, 2005 | 11:31 PM
Stock's Avatar
you have to reshim the 9 lb pulley. i think i used a .5" shim for that one opposed to none on my stock TRD pulley That could be very well that. But you got shims with your kit. I would check this first before you put yourself through a hell of a lot of trouble
The 9 lb pulley is smaller which means you need to shim it to get proper belt tension so it could be very well that your belt is slipping because of it being to loose. I am 90% sure it will be this since you do not have any shims. Talk to the dealership or whoever did the install to get the shims.
Old Dec 21, 2005 | 11:34 PM
Stock's Avatar
oh yah btw i think you are suppost to have less than 1/8" of play in the Serpentine Belt.
Old Dec 21, 2005 | 11:36 PM
Stock's Avatar
He already has a 110
Old Dec 22, 2005 | 12:38 AM
jrv2000's Avatar
sorry, didnt know
Old Dec 22, 2005 | 02:02 AM
madigan923's Avatar
i guess im a little confused about the shims. I thought the purpose was to center the pulley so the belt ran straight. could you explain a little. thanks for the help.
Old Dec 22, 2005 | 02:07 AM
Munch's Avatar
Thaty's what the shims are for. they have nothing to do with belt tension. If you put the stock pulley back on and the belt didn't squeal, then you have other issues. You could try to get a smaller belt and that would give you the proper tension needed for the smaller pulley.
Old Dec 22, 2005 | 02:29 AM
JT_Scion's Avatar
Woah! you get 9lbs of boost at 3800 rpms??? I get 9lbs at like 6200rpms.. HMMMMMM...
Old Dec 22, 2005 | 02:47 AM
hPower's Avatar
You may have already tried this, but see if you can get your belt tensioners tighter on the belt to get your belt on there as tight as possible. With supercharged motors belts have to be on almost insanely tight for everything to work with maximum efficiency. Keep us updated.
Harmonic_tC's Avatar
I had the same belt squeak with the ZPI pulley. I also dont have the SC but Talk to Kenny, and he should take care of you.
He is good with cust service
Old Dec 22, 2005 | 02:56 AM
motozen's Avatar
my problem is trying to keep traction between 3500 and 5000rpm in 2nd. Major wheel spin hehe.
Old Dec 22, 2005 | 02:59 AM
JT_Scion's Avatar
Is that because of the snow motozen? Seriously.. anyone else with the ZPI pulley and a boost gauge .. when are you seeing 9lbs?
Old Dec 22, 2005 | 06:46 AM
Stock's Avatar
sorry i meant 5800
Old Dec 22, 2005 | 11:03 AM
madigan923's Avatar
i havnt tried tightening the tension bolt.. but i will. if that doesnt work does anyone know the length of the stock belt so i can try to get a shorter one? thanks for all the help guys.
